Free Body Diagram Forces of a Rope Hoisting a Weight via Pillars
The discussion centers on designing an apparatus to lift a 500g load and calculating the forces involved. The user is unsure about the final position's reactions after lifting the load, having successfully determined the initial position. Key calculations indicate a horizontal tension component of 15 N and a vertical component of 2.5 N, leading to a total rope tension of approximately 15.2 N. The analysis suggests that the pillar experiences a reaction force of 13.2 N upward and 4.3 N horizontally, requiring stability at the base to counteract overturning moments. The final ground line reaction is noted to be 17.5 N upward with no horizontal component at the pillar base.
Gerard123
So I am designing an apparatus to lift a 500g load up 500mm and I am trying to find reactions. I have filled in these values in my head with my own logic but I don't know how to do the maths and if I am right or not.
I can do the initial position ok but it is the final position I am unsure of.
Here is what I have done:
https://www.dropbox.com/s/mirvwr2h13aajfp/Screenshot 2014-11-06 16.50.00.png?dl=0
When you pull up the load to its final position, the rope as you have noted on the right side of the left pillar has a horizontal tension component of 15 N and a vertical tension component of 2.5 N. Or a rope tension using Pythagoras Theorem of about 15.2 N.
Now presumably as you are pulling up the rope, you have some sort of pulley or smooth rounded edge at the top of the pillars. In which case, the tensions on both sides of the pulley are the same, and in which case the vertical component of the rope tension at the pulling end or anchored end is 15.2/sq rt 2 or about 10.7 N and the horizontal component is also 10.7 N. Thus, the pillar reaction is 13.2 N up and 4.3 N left. In other words, you have an unbalanced horizontal load inward at the pulley on the pillar top. You also have a ground line overturning moment at the pillar base, so the pillar requires fixity there.
Now once you snub off the rope between supports, ensure straightness of the pillar, and anchor your pulling end to the ground, then your ground line reaction is 17.5 N up, as you note, no horizontal component at base of pillar and no moment there either.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
