Calculating Terminal Velocity with Air Resistance: A Case Study in Free Fall
The discussion focuses on calculating terminal velocity while considering air resistance in free fall, referencing Newton's second law and the drag equation. It highlights that as an object's speed increases, the drag force becomes equal in magnitude and opposite in direction to gravitational force, leading to terminal velocity. The equation for terminal velocity is derived from setting the net force to zero, where drag force equals gravitational force. A correction is made regarding the use of vectors, clarifying that the minus sign in the force equations indicates direction, not magnitude. The conversation emphasizes the importance of accurately applying vector principles in physics calculations.
eehiram
My textbook source is:
Fundamentals of Physics, 6th edition, by Halliday, Resnick, Walker
According to Newton's well known 2nd Law of Motion:
Fnet = ma
In chapter 2, in the case of free fall, the Fgrav = mg,
where g = -9.8 m/s2, assuming that movement along the axis of y is positive going upward from the Earth's surface.
However, in order to make a slighter more elaborate calculation, let us attempt include to incorporate air resistance, as in chapter 6:
If we have the following values to insert into the Drag equation:
Mass density of air = ρ = 1.29 kg / m3
Object speed in m/s = v
Drag coefficient = Cdrag = needs to be looked up or calculated
Effective Cross-sectional Area in m2 = A
The drag equation in chapter 6, section 3 appears to be:
Fdrag = (1/2) ρv2CdragA
As air resistance increases with v2, the Fdrag reaches a value equal in magnitude and opposite in direction to Fgrav.
Then terminal velocity might be attained, and the object's free fall may cease to accelerate.
Terminal velocity vterminal can be solved for by calculating the case of Fnet = 0 = Fdrag + Fgrav
Fdrag = -Fgrav
(1/2) ρv2CdragA = -mg
etcetera...
Is this correct? This is not a homework assignment question.
Notice that if you try to solve your last equation for v, you'll end up taking the square root of a negative number. You can get rid of that pesky minus sign by going back to your net force equation and recognizing that it's a vector equation:
$$\vec F_{net} = 0 \\
\vec F_{drag} + \vec F_{grav} = 0 \\
\vec F_{drag} = - \vec F_{grav}$$
The last equation says that the two forces are opposite in direction (minus sign) and equal in magnitude:
$$F_{drag} = F_{grav}$$
This equation is for the magnitudes, so we drop the minus sign.
Yes, you are right. I should have used vectors in my initial post. Thank you for correcting my mistake.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
