Free Fall Equations on hot air balloon
A hot-air balloon descends at 2.0 m/s when a passenger drops a camera from 45m above the ground. To find the time it takes for the camera to reach the ground and its velocity just before landing, the appropriate equations of motion must be applied. The discussion emphasizes the need to rearrange the equations to isolate time and correctly account for the direction of motion. The quadratic formula is suggested as a method to solve for time after substituting the known values into the equations. Understanding these concepts is crucial for solving similar physics problems.
matace50
A hot-air balloon is descending at a rate of 2.0 m/s when a passenger drops a camera. If a camera is 45m above the ground when it is dropped, (a) how long does it take for the camera to reach the ground(b) what is the velocity just before it lands? Let upward be the positive direction for this problem.
I have to use either 2a x change in displacement= final velocity^2 - initial velocity^2 or
change in displacement= 1/2a x t^2 + initial velocity x change in time
a = acceleration t= time ^2= squared x= multiply
I think i somehow have to rearrange the equation to isolate t but i have no idea how. Can anyone help
For the first part, use the equation:
d = v1*t + (1/2)at^2
careful about signs... decide first if you want upward to be positive, or downward to be positive...
I see, but the problem doesn't give me time. I plugged everything in, but i still can't seem to get time.
(just started physics 2 weeks ago so I am kind of confused)
You have to use the quadratic formula to solve for time.
Ok now i understand. Thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
