Can Liquid Metals Defy Gravity and Form Perfect Spheres While Falling?
Liquid metals can form nearly perfect spheres when falling due to surface tension, similar to how lead shot is produced. This phenomenon occurs in free fall, where the absence of significant gravitational influence allows surface tension to dominate. While some argue that gravitational interactions among fluid particles contribute to this effect, the consensus is that surface tension is the primary factor. Liquid metals exhibit stronger surface tension than water, further facilitating their spherical shape. Overall, the behavior of liquid metals in free fall showcases the dominance of surface tension in shaping their form.
Brage Eidsvik
Will liquid metals create droplets when falling or will they create different shapes?
Welcome to PF;
They can form quite good spheres ... this is how lead shot used to be made.
Munitions companies would feed molten lead through a seive at the top of a tower, and it would literally rain little metal balls at the bottom.
http://www.ipenz.org.nz/heritage/itemdetail.cfm?itemid=2228
Likes Brage Eidsvik, Chestermiller, russ_watters and 1 other person
Yup ... and ball bearings :smile:
Likes Brage Eidsvik
I believe in free fall all liquid will ball up do to the surface tension the same way they do on iss or even in deed space without any gravitational fields around to react on it there's a name for this but i just can't remember it right now and i know that rain / water when it falls in the sky it pancakes a little bit because of the air friction when falling
throw some would say that the balling effect in free fall or weightlessness is do to the gravitational pull of all the fluids particles on ever other particles in the fluid like the sun and the planets do but for smaller thing i think it the surface tension
hope this helps:cool:
Likes Brage Eidsvik
The contribution from the droplet's own gravitational pull on itself is vanishingly small. The effect is essentially 100% from surface tension.
Likes Chestermiller and hsdrop
They can have stronger surface tension than water, that pulls them into a sphere:
https://en.wikipedia.org/wiki/Mercury_(element)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
