Free-hanging string with 4 attached masses
  • Thread starter Thread starter Nikitin
    String
The discussion revolves around a physics homework problem involving a massless string with four uniform masses attached symmetrically. The objective is to demonstrate the implicit equation for x, where x equals cos(alpha), is correct. Participants note the challenge of deriving five equations for five unknowns, as only four equations are being generated. They emphasize the importance of using tension notations and the relationship between the angles and distances in the problem. Ultimately, the user acknowledges a realization that clarifies their understanding of the equations needed to solve the problem.
Nikitin
http://home.phys.ntnu.no/brukdef/undervisning/tfy4145/ovinger/Ov03.pdf
look at "oppgave 5".
In the problem, you have a massless string with 4 uniform masses attached symmetrically, and you are supposed to show that the implicit equation for x (and x = cos(alpha)) is correct. Each of the masses are L/5 apart and the distance between the two ends of the string is D.
I should be getting 5 equations for the 5 unkowns, but I am only getting 4 (the last 4 equations written on the paper)..
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn2/1234158_10201385459335100_1607600845_n.jpg
This problem would make a lot more sense if I read Norwegian.
Look at the picture in the pdf: You see a massless string weighed down by 4 attached point-masses. Each of the mass is a distance L/5 apart from each-other, where L = total length of the string. D= distance between the two ends of the string.
Next you can see two angles: alpha and beta. The point with this problem is to show that the implicit equation for cosine of alpha written in the assignment,where x = cos(a), is correct.
Please tell me if there is something more you do not understand! I really need help with this
It is more convenient to simplify your notation by calling the tensions T and S.
Then use your D equation to get cosβ in terms of x where x = cosα.
I think that you do not need to use S_{3}.
You are probably right, but if I removed S_3 I would have 4 unkowns and 3 equations.. I don't understand how I can get my last equation?
Also sorry about the notation, but I took it from the assignment.
You have FOUR equations.
Two from vertical equilibrium and one from horizontal equilibirum if you do not use the third tension. But you have also your D equation from which to get cosβ in terms of x where x = cosα.
You mean those involving G? But G is also an unknown, because I don't know the mass. Do you think G would disappear if I inserted the equations into the one for D?
thanks for all help :)
OK after a fresh look at the problem I see you were completely right. thanks !
