Lunar_Lander
- 33
Consider the time-dependent one-dimensional Schroedinger Equation for the free particle, i.e. let the Potential be V(x)=0. Consider a wave packet, i.e.
\psi(x,t)=\int_{-\infty}^{\infty}=A(k)\exp[i(kx-\omega(k)t]dk.
Consider especially the Amplitude distribution
A(k)=\alpha\cdot\exp[-(k-k_0)^2\cdot d_0^2]\exp[-ikx_0]
(then it says "Gaussian Wave Packet").
For t=0, \psi(x,0) is given by a simple expression. Calculate this \psi(x,0) and sketch the associated probabilty density \rho(x,t=0)=|\psi(x,0)|^2. What must α be, so that the wave function is normalized, i.e. \int_{-\infty}^{\infty} \rho(x,t=0)dx=1? What is the physical meaning behind "the parameters" k_0, x_0, d_0?
Hint: \int_{-\infty}^{\infty} \exp[-(s+c)^2]ds=\sqrt{\pi} for all c\in ℂ
Schroedinger's Equation
Well, this is a big one. First of all I tried the final question. We were taught that there is a "k-Space" and a "position space" in which the probability density is a gaussian bell curve. x0 should be the highest point of the curve in the position space, whereas k0 is the corresponding amount in the k-space. Also, when I look at the lecture notes, k0 is a vector which corresponds to a wave with a certain momentum. Somehow I don't think that this explanation is too good. What do you think?
Now for the first question. I tried to insert the amplitude distribution into the wave function and then tried to combine the exponential functions. That looked like this:
\psi(x,0)=\int_{-\infty}^{\infty}{\alpha\cdot\exp[-(k-k_0)^2\cdot d_0^2]\exp[-ikx_0]\exp[i(kx)]dk}
\psi(x,0)=\int_{-\infty}^{\infty}{\alpha\cdot\exp[-(k^2-2kk_0+k_0^2)\cdot d_0^2]\exp[-ikx_0]\exp[i(kx)]dk}
\psi(x,0)=\int_{-\infty}^{\infty}{\alpha\cdot\exp[k^2d_0^2+2kk_0d_0^2+k_0^2d_0^2]\exp[-ikx_0]\exp[i(kx)]dk}
And finally arrived at
\psi(x,0)=\int_{-\infty}^{\infty}{\alpha\cdot\exp[k^2d_0^2+2kk_0d_0^2+k_0^2d_0^2-ikx_0+ikx]dk}
I was told that I would now have to use a completing the square to bring that into a form Ak^2+Bk+C, so that I could use the "hint" given in the task. But I got some kind of mental block there. Could someone please help me?
Final question: Is it true that when we look for α, all that has to be done is to set the Integral of ρ multiplied by α equal to 1 and α then is like 1/ρ ?
