Why is Wavenumber (1/cm) Considered a Unit of Frequency?
  • Thread starter asdf1
In summary, frequency refers to the number of occurrences of a repeating event per unit time, while wavenumbers refer to the number of waves that pass a fixed point per unit distance. They are related through the formula wavenumber = frequency * speed of light. In spectroscopy, frequency and wavenumbers are used to measure the energy of electromagnetic waves and identify the chemical composition of substances. In terms of IR and Raman spectroscopy, IR typically uses higher frequencies and wavenumbers compared to Raman. In NMR spectroscopy, frequency and wavenumbers are used to measure energy differences between spin states of atomic nuclei. In spectroscopy, frequency and energy are directly proportional, with higher frequency waves having higher energy
asdf1
734
if frequency is (1/sec), then why is wavenumber (1/cm) considered a unit of frequency?
It is considered the spatial representation of frequency, it in itself is not a fequency. However, you can obtain the the wavenumber by dividing the frequency by the speed of light. Observe,
[tex]c = f\lambda \Leftrightarrow \frac{1}{\lambda} = \frac{f}{c}[/tex]
[tex]\frac{1}{\lambda}\propto f[/tex]
wow! never thought of it that way before~ thank you!
Related to Why is Wavenumber (1/cm) Considered a Unit of Frequency?
1. What is frequency and how is it related to wavenumbers?
Frequency refers to the number of occurrences of a repeating event per unit time. It is typically measured in hertz (Hz). Wavenumbers, on the other hand, refer to the number of waves that pass a fixed point per unit distance. They are usually measured in units of inverse meters (m^-1). Frequency and wavenumbers are mathematically related through the formula: wavenumber = frequency * speed of light.
2. How are frequency and wavenumbers used in spectroscopy?
In spectroscopy, frequency and wavenumbers are used to measure the energy of a particular electromagnetic wave. This is because the energy of a wave is directly proportional to its frequency and inversely proportional to its wavelength (which is related to wavenumbers). Spectroscopy techniques use this relationship to identify and analyze the chemical composition of substances based on the unique energy signatures of their molecular vibrations or electronic transitions.
3. What is the difference between infrared and Raman spectroscopy in terms of frequency and wavenumbers?
Infrared (IR) and Raman spectroscopy are both techniques used in spectroscopy to analyze the vibrational energy levels of molecules. The main difference between the two is that IR spectroscopy measures the absorption of infrared light by a molecule, while Raman spectroscopy measures the scattering of light. In terms of frequency and wavenumbers, IR spectroscopy typically uses higher frequencies and wavenumbers (4000-400 cm^-1) compared to Raman spectroscopy (400-10 cm^-1).
4. How are frequency and wavenumbers used in nuclear magnetic resonance (NMR) spectroscopy?
In NMR spectroscopy, frequency and wavenumbers are used to measure the energy differences between the different spin states of atomic nuclei in a magnetic field. This allows for the identification and characterization of molecules based on their unique NMR spectra. The frequency of the radio waves used in NMR spectroscopy is typically in the range of 10-1000 MHz, which corresponds to wavenumbers of 1-100 m^-1.
5. What is the relationship between frequency and energy in spectroscopy?
In spectroscopy, frequency and energy are directly proportional. This means that the higher the frequency of a wave, the higher its energy and vice versa. This relationship is described by the equation: energy = Planck's constant * frequency. This is why spectroscopy techniques, such as IR and NMR, use the frequency/wavenumber measures to determine the energy levels of molecules and identify their chemical composition.
  • Quantum Physics
