Frequency of small oscillations about equilibrium point.
5 replies · 22K views
bjw1311
A particle of mass m moves in one dimension subject to the potential:
V(x)=(-12/x)+(x^-12)
Find the equilibrium point and the frequency of small oscillations about that point.
I think I've found the equilibrium point 'a', but using the formula V'(a)=0, and i got the answer a=1.
However, I am completely stuck on finding the frequency, I've found the Lagrangian and hence the equation of motion, but then don't know what to do.
any help much appreciated! :)
Ok, you don't need the equations of motion to find the frequency of small oscillations.
Here's what you need to do:
At x=1, there's a stable equilibrium. For very small oscillations, it will approximate a SHO. So all you need to do is fit a parabola to that point by:
1. Putting the equilibrium point of the parabola at the (x=1, y=?) point.
2. Making the first derivative of the parabola equal the derivative at the point (of course, this has already been done for you by using a parabola).
3. Making the second derivative match the second derivative of your potential function there.
So what's the equation of a parabola?
y = ax^2 + bx + c
y' = 2ax + b
y'' = 2a
So all you need to do is to make sure that y(1) = V(1), y'(1) = V'(1), and y''(1) = V''(1).
Then simply realize that F = -kx by Hooke's law, and that F = -y'. So whatever the coefficient on the 'x' term in your y' happens to be, that equals k. From that and the mass m, it should a straightforward exercise to find everything else you could want.
ive managed to work out what you've said but i don't understand why?
sorry,
i don't understand why you need to fit the parabola at that point, and i don't really get how you do it, do you equate the V's and y's to find the values of a, b and c? and how does this help?
and i don't see how to use the info to find the oscillations :(
forget it! I've figured it out! temporary blank.
thanks very much for your help.
The idea is that for small displacements from a stable equilibrium, all oscillations look like simple harmonic oscillations.
Simple harmonic oscillations are described by a parabolic potential well.
So by finding the parabola which best approximates your potential function V at the point of stable equilibrium, you will find the SHO potential which best approximates the oscillatory behavior near the equilibrium.
To find the best-fit parabola at your point, you have to make it match your V in its zeroth, first, and second derivatives; you have to find the 2nd order Taylor polynomial for the potential function V expanded around the point of equilibrium.
The system of equations I suggested fits the parabola.
Once you have the parabola for the SHO, it's easy to use Hooke's law to find k, and once you have k and m, you can easily find everything else.
