Friction, circular motion (stupid question)
The discussion focuses on determining the maximum speed a car can maintain while navigating a circular bend, considering the friction between tires and the road. The correct formula derived is v = √(rgμ), where r is the radius, g is gravitational acceleration, and μ is the coefficient of friction. The confusion arises from the distinction between static and kinetic friction; while kinetic friction opposes motion, static friction provides the necessary centripetal force for the car to turn. It is clarified that static friction acts toward the center of the circular path, enabling the car to maintain its trajectory. Understanding this distinction resolves the initial misunderstanding about the role of friction in circular motion.
robs
A road bend is circular with a radius r, the surface is horizontal. The coefficient of friction between car tires and dry asphalt is \mu.
Determine the maximal speed with which a car can drive through the bend.
Actually, I have solved the problem (and checked with the answers given in the textbook), but I don't really understand it.
I simply said that the centripedal force is m\cdot v^2/r (m is the mass of the car) which at the maximal speed is equal to the friction force mg\mu, so I get v = \sqrt{rg\mu} which apparently is right.
However, where does the fricition force comes from? I was taught that in fact the friction force {\bf F_f} = -\mu N {\bf v}/|{\bf v}| (at not too high velocities), so the friction force is oppositely directed to velocity. In the above however, I assumed that the friction force is oppositely directed to the centripedal acceleration (which is perpendicular to velocity), so actually, the friction force shouldn't have any effect on the motion...
Where is my error in reasoning?
This would describe kinetic friction, but the friction force on the car tires in your problem is static friction.
The friction is what produces the centripetal acceleration, so it must act toward the center (in the same direction as the centripetal acceleration). No friction and the car couldn't turn.
