High School Friction forces on the tires of a moving car
When a car is moving at a constant velocity, the connection point between the tires and the ground has zero velocity, indicating that static friction is at play. Kinetic friction only occurs when tires slip, such as during hard acceleration or braking. While a car can theoretically maintain constant velocity on a frictionless surface, in reality, static friction is necessary to overcome aerodynamic drag. Aerodynamic drag increases with speed and can be linear or quadratic depending on the velocity. Understanding these friction types is crucial for grasping vehicle dynamics and performance.
titasdasplus
When a car is moving the velocity of the connection point between the car and the ground is zero. So static friction must be act here ,mustn't it ? But my mentor said ,it is kinetic friction. Which is correct? If kinetic friction, why?
Your mentor is completely wrong. There is no active friction force on a car moving at constant velocity. A car could move normally at constant velocity on a frictionless surface.
When the car accelerates, turns or brakes, static friction acts to provide the external force. Only if the wheels lock and the car skids does kinetic friction apply.
Note that tires are made of rubber with a high coefficient of friction. This allows greater acceleration and grip on the road. This would be an absurd design if kinetic friction were acting while driving.
A car moving on a flat surface will gradually lose speed through air resistance and rolling resistance, which is caused by the interaction of the tires deforming slightly against the surface. I.e. the tires cannot remain perfectly circular. But not by kinetic friction.
Cars are designed to ideally use static friction with the road to accelerate or brake. If you accelerate or brake too hard, the tires will slip and you have kinetic friction. You also have rolling resistance, which is not road friction but a combined effect of deformations and internal frictions.
Although I agree that the mentor is completely wrong, I don't understand the part after that. There is aerodynamic drag acting on the car which means that a constant force is necessary to maintain constant velocity. This means a car cannot maintain constant velocity at a frictionless surface, you need the friction between the tire and road to overcome the aerodynamic drag. This is of course still static friction.
Well, I did say "could" rather than "would". We'd also need no air resistance for the already hypothetical scenario to apply.
That's just too subtle for me to pick up 😆
Can you tell me about aerodynamic drag?
That is a pretty open ended question. What do you want to know?
Aerodymamic drag is a force that opposes the motion of an object through a gas. The faster the object moves relative to the gas, the larger the drag force becomes.
At low speeds where not much energy is imparted to the gas, aerodynamic drag scales linearly with relative velocity. The drag in this regime depends on the viscosity of the gas.
At higher speeds, turbulence comes into play and aerodymic drag scales quadratically with relative velocity. The drag in this regime depends on the density of the gas. Cars on the highway typically operate in the quadratic regime.
Likes russ_watters
  • · Replies 73 ·
10K
  • · Replies 20 ·
  • · Replies 95 ·
  • · Replies 29 ·
