Friction problem on inclined plane
The discussion revolves around calculating the speed of an object at the bottom of a rough inclined plane and determining the coefficient of kinetic friction on a horizontal surface. The user calculated the speed to be 12.65 m/s using the energy conservation equation, but was advised that friction must be considered, indicating that non-conservative work should be factored in. For the horizontal surface, the user derived a coefficient of kinetic friction of 0.35, but was reminded to account for the angle and the normal force in their calculations. The importance of correctly applying the work-energy principle in the presence of friction was emphasized. Overall, the calculations and methodology were mostly correct, but adjustments for friction effects were necessary.
jhrnndz1
Alright, I have another question that I want to make sure I did correct. The question is "an objec of mass m is at rest on a rough inclined plane with height h, length 8 m, and which makes an angle of 30degrees with the horizontal. The object is allowed to move and it stops on a rough horizontal surface, at a distance of 4m from the botton of the inclined plane as shown. The coefficient of kinetic friction on the inclined plane is 0.4 and g=10m/s^2.
What is the speed of the object ast the bottom of the inclined plane?
Alright i used the equation KEfinal -PEfinal = KEinitial -PEinitial, put in the numbers and calculated the velocity to be 12.65 m/s.
The second questin is...
What is the coefficient of kinetic friction for the horizontal surface?
I used the equation Normal force = Force of weight and got
mass*gravity*distance *coefficient of kinetic friction = mass*gravity*distance*coefficient of friction on the incline.
I canceled the mass and the gravity and put in the numbers,
(4m for distance on horizontal0*(uk)= distance of 4 m, (which i obtained from sin30=8/d)*cos30degrees*0.4(the planes coefficient of friction).
I then solved for the coefficient of fricton from the horizontal and calculated 0.35.
(Is this correct?
You do NOT have conservation of mechanical energy, since friction is present!
So, for part A, would I first find the Wnc=-ukmgd, and then set that equal to change of KE + the change of PE?
You have to factor in the angle. The force of friction is \mu_kNg where N is the component of the block's weight perpendicular to the inclined surface. Apart from that, your approach is right.
AM
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
