Friction problem with hardly any variables given
The discussion centers on calculating the stopping distance of a car moving at 100 km/h on different inclines, given a minimum stopping distance of 60 m on level ground. Participants highlight the lack of necessary variables, such as the coefficient of friction (uk) and mass, which complicates the problem. A suggested approach involves analyzing the forces acting on the car on an incline, specifically the gravitational component and the deceleration due to friction. By setting up the net force equation and canceling mass, one can derive the acceleration needed for further calculations. The conversation concludes with a participant expressing understanding and intent to apply the discussed method.
mooney82
The minimum stopping distance for a car from an initial 100km/h is 60 m on level ground. What is the stopping distance when it moves (a) down a 10 degree incline; (b) up a 10 degree incline? Assume the initial speed and the surface are unchanged.
Fk=uk*N
I have no clue how to solve this. There is no uk value given, no mass given, or a force. I can find the acceleration of the car on a level surface (-6.431) but not sure how to find force without mass, how to find the N value without the mass or the uk value.
If that is all you are given, maybe try using the kinematic equations on the angle of the plane. What I'm saying is find the component of acceleration due to gravity in the plane of the inclined plane and try manipulating the two accelerations to get a correct stopping distance.
But without the mass you can't find out the acceleration due to gravity.
Without the force you can't find the mass.
Are you sure that the question wants a quantitative answer and not a qualitative answer?
Actually, try this. When the car is on the incline plane, there is a force that wants to pull the car down the plane and that force is mgsin(theta). However, the car is also stopping or decelerating. We found that on flat ground, a=-6.43. So on the inclined plane to find the component along the plane, we must multiply by cos(theta). The force of this will be the cars mass, m, times the acceleration, -6.43cos(theta). Therefore, your net force will be mgsin(theta)-6.43m=ma. You can then solve this for a and the m's will cancel. Then plugging in this a into the kinematic equation, you can find the stopping distance. Understand?
Ya, I think so. I'll try it tomorrow, thanks a lot!
