Friction question, maximum incline
To determine the maximum incline angle (alpha) for a 50kg object on a rough plane, the forces acting on the object must be analyzed. The tension in the string, which has a breaking strain of 200N, must balance the gravitational component and frictional force. The equation derived is 50g sin(alpha) = 200 + 10g cos(alpha). To solve for the maximum alpha, a substitution using trigonometric identities is suggested, where sin(alpha) is represented as x and cos(alpha) as √(1-x²). This approach allows for the expression of the left-hand side as a single trigonometric function, facilitating the determination of the largest angle before the string breaks.
Kinhew93
An object of mass 50kg rests on a rough plane incline at an angle alpha to the horizontal. It is supported in this position by a light string parallel to the plane. The string has a breaking strain of 200N and the coefficient of friction between the object and the plane is 0.2. Find the largest value of alpha for the string to remain intact.
Resolving parallel to the plane:
50gsin(alp) = 200 + (0.2x50gcos(alp))
= 200 + 10gcos(alp)
So it seems that I have to find the maximum value of alpha for which the above equation is true, but I have no idea how to do that.
Any help would be much appreciated. Thanks :)
why not take sin(α)=x and cos(α)=√(1-x2)
Likes 1 person
You can rewrite as $$50g \sin \alpha - 10 g \cos \alpha = 200$$ and express the LHS as one trig function and a corresponding phase.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
