Frictionless half-pipe and rotational motion question
35 replies · 9K views
Doc Al said:
Yes, the triangle you've drawn is incorrect. (But the direction of the force and tangent line are correct, which is what I was focusing on. Sorry about not pointing that out!) Since you are finding components of the weight, you must draw a new right triangle in which the weight is the hypotenuse.
Sanity check: A vector must always be bigger (or at least equal to) its components. So when drawing a right triangle to find components, the components must be the smaller sides, not the hypotenuse.
Ok. I drew my triangle with the mg. I found the components to be:
x = mgcos30
y = mgsin30
We're looking for the x component as the acceleration, so then we can go: mgcos30 = ma. Cancel out the masses, solve for acceleration.
a = gcos30
a = 8.5units/s^2
Right? (Please say yes... ha ha)
x = mgcos30
y = mgsin30
a = gcos30
a = 8.5units/s^2
I'm thinking this would make sense because at angles of 0 and 180, the acceleration is equal to gravity.
x = mgcos30
y = mgsin30
a = gcos30
a = 8.5units/s^2
Right! (or yes, if you prefer!)
Alright! Last question, I promise: Why is it that the x component gives you the acceleration? I realize that I got the right answer but I'm not so sure as to how I got it. I just assumed it was that way because when you put in cos(0)*9.8 you got 9.8. Which makes sense because the circle is completely vertical at that point.
All you're doing is applying Newton's 2nd law in the tangential direction. For the tangential forces (the x-direction), the only force is the x-component of the weight. So:
ƩFx = max
mg cosθ = max
So... ax = g cosθ
Let me know if this gets at your question. If not, ask again.
ƩFx = max
mg cosθ = max
So... ax = g cosθ
Ok... I think I get it now. Thanks a lot. Just one more picture to make sure my triangle is in the right spot:
