Converting Spherical to Cylindrical Coordinates for a Velocity Expression
Niles
Hi
I have an expression on the form
<br /> df(v, \theta, \phi) = v e^{-v^2/C}\cos(\theta)v^2\sin(\theta)\,dv\,d\theta\,d\phi<br />
and I am trying to write it in cylindrical coordinates. Note that θ runs from 0..π, v is a velocity and C a real constant. So I wish to write it in terms of a radial and axial velocity, vr and vz.
First I thought of integrating out θ and \phi. \phi is easily done, and it yields 2π. However, the integral over θ yields 0. Am I doing this wrong?
The result should yield something proportional to
<br /> v_re^{-v_r^2/C^2}v_ze^{-v_z^2/C^2}\,dv_r\,dv_z<br />Niles.
In spherical coordinates the integral over theta runs 0 to pi.
Hi
Thanks for replying. The integral of cos(theta)sin(theta) over 0..pi gives 0.
Oh, right. I looked at the sin(theta) and didn't see the other term.
OK, I am taking a different approach now. Now I use v_r = v\cos(\theta) and v_z = v\sin(\theta). This gives me
<br /> v_rv_zv\,dv\,d\theta<br />
Then I use (from http://en.wikipedia.org/wiki/Spherical_coordinate_system) that \arctan(v_r/v_z) and v=\sqrt(v_r^2+v_z^2) to find dv/dvr and dθ/dvz. However, don't get the desired results.
Is my approach wrong?
Niles.
Basically, what you're trying to do is express a complete sphere with radius = v, in terms of cylindrical coordinates, with density v e^{-v^2/C}\cos(\theta). So, forget about the density for now, and focus on the conversion to cylindrical coordinates. Afterwards, plug in the density.
Thanks for taking the time to help me. For the conversion I get
<br /> v e^{-v^2/C}\cos(\theta)v^2\sin(\theta) = v_rv_zv e^{-\sqrt{v_r^2+v_z^2}/C}<br />
I have used the relations I linked to above. Can I get a hint to how I should take care of the density?
Best wishes,
Niles.
Ahh, I think I get it now. So what you mean is that
<br /> v\,dvd\theta = dv_r\,dv_z<br />
Then it adds up!
In cylindrical coordinates r measures the distance from the origin to the foot of the projection from the point to the xy-plane. The line from the origin to the point in 3 dimensions, the line from the origin to the point at the foot of the projection and the projection form a straight line with hypotenuse of length \rho, angle \pi/2- \phi, "opposite side" of length z, and "near side" of length r. That is, the point that has spherical coordinates \rho, \theta, and \phi has cylindrical coordinates r= \rho sin(\phi), \theta= \theta and z= \rho cos(\phi).
Here, I have used the mathematics convention that \theta is the "longitude" and \phi is the "co-latitude". The physics convention reverses that.
My understanding of the problem is in the attached graph below.
In this problem, \phi is substituted by \theta, \theta is replaced by \phi, and \rho is replaced by v.
So, a description of the sphere would be:
For \phi and \theta fixed, v varies from 0 to v.
For \phi fixed, \theta varies from 0 to ∏.
\phi varies from 0 to 2∏.
The corresponding description in terms of cylindrical coordinates would be:
For \phi and r fixed, z varies from -\sqrt{v^2-v^2\sin^2\theta} to \sqrt{v^2-v^2\sin^2\theta}, where \theta is \arctan ({\frac {r}{z}}).
For \phi fixed, r varies from 0 to v.
For the integrand:
v e^{-v^2/C}\cos(\theta)Replace \theta by \arctan ({\frac {r}{z}}) and v by \sqrt{r^2+z^2}.
Thanks for the help, both of you.Niles.
