How Do You Determine the Image and Pre-Image of Intervals in Functions?
  • Thread starter Thread starter missavvy
    Function Interval
missavvy
Define f(x) = |x| - 1, what is f((-2,3])?
What is f-1((-2,3])?
[-2,1] is the answer for the first part.
I don't understand why though... so you have
f((-2,3]) = |(-2,3]| - 1
I don't quite get how to take the absolute value of an interval. Could someone maybe explain it to me?
THANKS!
this isn't correct, think of the function operating on an interval to give all points defined as
f{(a,b)} = {f(x) | x is in (a,b)}
now what is the minimum f(x) = |x| - 1 can be for any x?
what is f(-2), f(3), and f(0)
You don't "take the absolute value of an interval".
For set A, f(A) means the set of all values of f(x) for x in A: f(A)= \{f(x)| x\in A\}.
For x between -2 and 0, |x|= -x so f(x)= |x|- 1= -x- 1, a linear function. f(-2)= 2- 1= 1 and f(0)= 0- 1= -1 so for x between -2 and 0, f(x) takes on all values between -1 and 1.
For x between 0 and 3, |x|= x so f(x)= |x|- 1= x- 1, a linear function. f(0)= -1 and f(3)= 2 so for x between 0 and 1, f(x) takes on all values between -1 and 2.
That is, for all x between -2 and 3, f(x) takes on all values between -1 and 2. Notice that -2 is not included in (-2, 3] but f(-2)= 1= f(2) so f((-2, 3])= [-1, 2].
f^{-1}(B) is set of all x values such that f(x)\in B.
Notice that, even though the function f(x)= |x|- 1 is NOT one-to-one and so does NOT have an inverse (that is, f^{-1}(x) is not defined) f^{-1}(-2,3]), applied to a set, is defined. If we look at x< 0, we see that f(x)= |x|- 1= -x- 1= 3 when x= -4. f(x) is never equal to -2 but does go between -1 and 3 (and so is in (-2,3]) for x between -4 and 0. For x> 0, f(x)= |x|- 1= x- 1= 3 when x= 4. Again it does not go down to -2 but for every x between 0 and 4, lies in the set (-2, 3]. That is, f^{-1}((-2, 3])= [-4, 4].
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
