Function of a Battery in Simple Circuits
In summary: A battery creates potential difference between two points in a conductor. This potential difference is what allows the electric field to move charges around. When current flows through the battery, the electric field is directed towards the current. This is why batteries move positive charge from low potential to higher potential.
Bheshaj
In a simple circuit with battery connected to a resistor or a combination of resistors where is the electric field directed . What do we mean when we say battery creates a potential difference between two points in a conductor? And by the statement that battery moves positive charge from low potential to higher potential?
what have you done so far to try and find some answers ?
show your effort and people here will guide you :smile:
Likes berkeman
Please help me. I am not understanding, these statements are directly said by people and written in books tried a lot to find out their meaning. .What do they mean when they say we apply a potential difference. There should be an electric field right to move charges how and where is it directed in a battery and in wires and resistors connected to the battery?
Potential difference is a reference to voltage, which is the electrical potential energy per unit (positive) charge. As a crude analogy, it's similar to gravitational potential energy per unit mass (I'm not aware of a term for gravitational potential).
Consider the case of a constant intensity field, which can be approximated by the inner part of a field between two charged plates (such as a capacitor), with a positively charged particle within that field. The voltage is greatest at the more positively charged plate, and zero at the more negatively charged plate. A positively charged particle would experience a constant force towards the more negatively charged plate.
Likes Bheshaj
The preferred way of working problems with circuit diagrams is to ignore the real-world aspects of the situation and consider the circuit elements as idealizations. They have certain behavior, because they are defined to.
Idealization: A battery is a device that will impose a defined potential difference between its terminals regardless of how much current passes through it. The current can pass through in either direction.
Analogy: If your intuition balks at the idea of abstractions like this, the fluid analogy may be helpful. Potential (voltage) is like pressure in a pipe. A battery is like a pump that imposes a pressure difference. Normally, it does this by pumping fluid received on the low pressure end out to the high pressure end. It imposes the same pressure difference regardless of the flow rate. Negative flow rates are possible -- if the fluid is driven from elsewhere, the pump can absorb energy from the flow like a turbine.
Realistic: A realistic battery operates based on chemistry. Current flows as the battery's chemical stockpile is used up, slowly reducing the potential that the battery is able to provide. A reverse flow allows the chemical stockpile to be restored -- recharging the battery.
In idealized circuit theory one assumes an infinite chemical stockpile with no reduction in voltage as current continues to flow.
Likes Bheshaj and vanhees71
What is a battery and how does it work in simple circuits?
A battery is a device that converts chemical energy into electrical energy. In simple circuits, the battery acts as the power source, providing a potential difference or voltage that pushes electrons through the circuit.
What is the function of a battery in a simple circuit?
The main function of a battery in a simple circuit is to provide a source of electrical energy. This energy is used to power devices and create an electric current that can do work.
How does a battery maintain a constant voltage in a simple circuit?
A battery maintains a constant voltage in a simple circuit through its internal chemical reactions. The chemical reactions produce a flow of electrons, creating a potential difference or voltage. This voltage remains constant as long as the chemical reactions continue.
What happens to a battery when it is connected to a simple circuit?
When a battery is connected to a simple circuit, the chemical reactions inside the battery create a flow of electrons, which creates a potential difference or voltage. This voltage then pushes the electrons through the circuit, powering the devices connected to it.
How long does a battery last in a simple circuit?
The lifespan of a battery in a simple circuit depends on several factors, including the type of battery, the devices connected to the circuit, and the rate at which the battery is drained. Generally, a battery will last longer in a simple circuit if it is not constantly being drained at a high rate.
  • Classical Physics
  • Electromagnetism
  • Classical Physics
