Calculating Derivative of h(x) using Fundamental Theorem
The discussion focuses on using the Fundamental Theorem of Calculus to find the derivative of the function h(x) defined as the integral of arctan(t) from 2 to 1/x. The key point is that the theorem states the derivative of an integral function F(x) is equal to the integrand evaluated at the upper limit. Since the upper limit is 1/x, the chain rule must be applied, leading to the expression for the derivative. The final result for the derivative h'(x) is -1/x^2 * arctan(1/x). This illustrates the application of calculus principles in evaluating derivatives of integral functions.
tandoorichicken
Hello everyone, its been a while.
It's been almost 4 months since I did anything calculus related so I forgot all of my skills. :bugeye:
The problem is:
Use the Fundamental Theorem of Calculus to find the derivative of the function
h(x) = \int_{2}^{\frac{1}{x}} \arctan{t} \,dt
IIRC (whichI might not) the fundamental theorem of calculus says that given F(x) = S(f(x),x,a,b) F'(x) = f(b)-f(a)
Consider the function F(x) = \int_{a}^{x} f(t) \,dt.
The Fundamental Theorem of Calculus is given by: \frac{dF}{dx} = f(x). In your case the upper integration limit is 1/x. Therefore, you will have to use the chain rule. Let u=1/x \Rightarrow \frac{dh}{dx} = \frac{dh}{du}\frac{du}{dx} = -\frac{1}{x^2}arctan(\frac{1}{x})
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
