Discover the Latest Baryonic Mass Figures from the Galaxy Red Shift Survey
In summary: He started working on it in the 70s and has written a number of papers on the topic.Primordial Alchemy: From The Big Bang To The Present UniverseIn summary, Garth By CHRONOS discusses the Primordial Alchemy theory, which suggests that the universe has gone through a cycle of creation and destruction.
wolram
Dearly Missed
4,446
558
The latest figures for baryonic mass etc.
Astronomy news on Phys.org
Hi wolram, I think for some reason you did not get the URL into the post, at least at first.
I think the URL is
http://arxiv.org/abs/astro-ph/0501174
The 2dF Galaxy Redshift Survey: Power-spectrum analysis of the final dataset and cosmological implications
S. Cole et al., (The 2dFGRS Team)
"We present a power spectrum analysis of the final 2dF Galaxy Redshift Survey, employing a direct Fourier method. The sample used comprises 221,414 galaxies with measured redshifts. We investigate in detail the modelling of the sample selection. A new angular mask is derived, based on revisions to the photometric calibration. The redshift selection function is determined by dividing the survey according to rest-frame colour, and deducing a self-consistent treatment of k-corrections and evolution for each population. The covariance matrix for the power-spectrum estimates is determined using two different approaches to the construction of mock surveys which are used to demonstrate that the input cosmological model can be correctly recovered. We are confident that the 2dFGRS power spectrum can be used to infer the matter content of the universe. On large scales, our estimated power spectrum shows evidence for the `baryon oscillations' that are predicted in CDM models...
... This shift is largely due to the signal from the newly-sampled regions of space, rather than the refinements in the treatment of observational selection. This analysis therefore implies a density significantly below the standard $\Omega_{M} =0.3$: in combination with CMB data from WMAP, we infer $\Omega_{M} =0.231\pm 0.021$."
stranger and stranger
It used to be that Dark Energy was 70 percent and Matter (baryonic plus dark) was 30 percent
now, if I understand the abstract, they want us to believe that Matter is only 23 percent. Maybe i am missing something. i will take more of a look.
they could be wrong, I guess. Maybe someone who follows this will comment.
Sorry Marcus i did post the url, maybe some problem my end.
This one has me thinking, perish the thought, i think that something
is going on in the quantum world that we do not know about.
The bimodal distribution of the data is really striking.
The best guess numbers have hovered around 25 - 75 for the past few years:
http://arxiv.org/abs/astro-ph/0302207
This flat universe model is composed of 4.4% baryons, 22% dark matter and 73% dark energy
I could have told you that! [http://www.kluweronline.com/oasis.htm/5092775 predicts a cold matter density of 22.2% (2/9)]
Garth
By CHRONOS
I think i read somewhere that if baryonic mass exceeded 4.4% by
a few percent, then the big bang model would be in trouble, if this
is so what is the max min baryonic matter allowable in the BB model
wolram said:
By CHRONOS
Start here:
http://arxiv.org/abs/astro-ph/0208186
Steigman is one of the foremost authorities on BBN.
What is a galaxy red shift survey?
A galaxy red shift survey is a scientific study that involves measuring the red shift of galaxies in order to determine their distance from Earth. This information can then be used to map the structure and expansion of the universe.
Why is a galaxy red shift survey important?
A galaxy red shift survey is important because it helps scientists understand the large-scale structure of the universe, including the distribution and movement of galaxies. This information can also provide insights into the history and evolution of the universe.
How is red shift measured in a galaxy red shift survey?
Red shift is measured by observing the spectrum of light emitted from a galaxy. The wavelengths of the light will appear longer (or "shifted" towards the red end of the spectrum) if the galaxy is moving away from Earth. This is known as the Doppler effect.
What tools are used in a galaxy red shift survey?
The main tool used in a galaxy red shift survey is a spectrograph, which splits light into different wavelengths and allows scientists to measure the red shift of galaxies. Other instruments used may include telescopes and specialized cameras.
What can we learn from a galaxy red shift survey?
A galaxy red shift survey can provide information about the expansion rate of the universe, the distribution and movement of galaxies, and the effects of dark matter and dark energy. It can also help scientists test and refine theories about the origin and evolution of the universe.
  • Astronomy and Astrophysics
