What factors contribute to the deflection of a galvanometer?
In summary, a galvanometer is designed with radial magnetic poles to ensure a radial magnetic field. This means that the angle between the magnetic moment of the coil and the field is zero, so there should be no torque when current is passed through the coil. However, there is still deflection, which may cause confusion. The galvanometer works as described in the link provided, where a soft iron cylinder strengthens the radial magnetic field and keeps it parallel to the coil's plane. This means that the field is not perpendicular to the coil's area, but it still allows for accurate measurements. For further clarification, refer to the additional source provided.
Sukuya
In a galvanometer the magnetic poles are cut in such a fashion which ensures radial magnetic field. If field is radial then the angle between magnetic moment i.e Area vector of the coil and field is zero. Thus the coil should not experience any torque when current is passed through the coil. Then how come there is deflection.
Yes, like this one. The link says :
"In the space between it and the pole pieces, where the coil moves freely, the soft iron cylinder makes the magnetic field stronger and radial such that into whatever position the coil rotates, the magnetic field is always parallel to its plane."
My doubt is that when field is radial it should be perpendicular to the area of coil rather than parallel to its plane.
The deflection of a galvanometer is not solely based on the angle between the magnetic moment and the radial field. There are other factors at play, such as the strength of the magnetic field and the current passing through the coil. Additionally, the design of the galvanometer may also play a role in the deflection.
In a galvanometer, the coil is suspended within the magnetic field and is able to rotate freely. When a current is passed through the coil, it creates a magnetic field around the coil which interacts with the external magnetic field. This interaction results in a torque being applied to the coil, causing it to rotate and deflect.
Furthermore, the radial field in a galvanometer is not perfectly uniform and may have variations in strength and direction. This can also contribute to the deflection of the coil.
In summary, the deflection of a galvanometer is a complex phenomenon that involves multiple factors, not just the angle between the magnetic moment and the radial field. It is important to consider all these factors when analyzing the behavior of a galvanometer.
What is a galvanometer?
A galvanometer is a scientific instrument used to detect and measure small electrical currents. It typically consists of a coil of wire suspended in a magnetic field and a pointer that moves in response to the current passing through the coil.
How does a galvanometer work?
A galvanometer works based on the principle of electromagnetism. When an electrical current passes through the coil, it creates a magnetic field around it, which interacts with the external magnetic field and causes the coil to move. The movement of the coil is then registered by the pointer, providing a measurement of the current.
What is a radial field in a galvanometer?
A radial field in a galvanometer refers to the shape of the external magnetic field that the coil is suspended in. It is a circular or radial shape, with the coil at the center. This type of field is necessary for the proper functioning of a galvanometer.
What are the applications of a galvanometer?
Galvanometers have various applications in science and engineering. They are commonly used in electrical circuit testing, as well as in the measurement of small currents in scientific experiments. They are also used in medical equipment, such as electrocardiographs, to measure the electrical activity of the heart.
What is the difference between a galvanometer and an ammeter?
A galvanometer is a more sensitive instrument than an ammeter, meaning it can detect and measure smaller currents. Galvanometers are typically used in laboratory settings, while ammeters are used for measuring larger currents in industrial or commercial settings. Additionally, ammeters are designed to have a low resistance, while galvanometers have a higher resistance to prevent damage from larger currents.
  • Electromagnetism
  • Classical Physics
  • Electromagnetism
