gravenewworld
- 1,128
- 27
Evo said:Bottled water is not only a silly, unnecessary extravagance, the amount of plastic it is adding to landfills is horrendous. Buy a plastic bottle, fill it with water, rinse, repeat.
mgb_phys said:Coke launched Dasani bottled water in the UK
First they got into trouble with the advertising standards agency for describing it as pure when it was simply London tap water, then it was 'voluntarily withdrawn' when it turned out that their bottling process added unacceptable levels of carcinogens.
A friend of mine is having chemotherapy, one of the warnings is to only drink freshly poured tap water because of the risk of bacteria in bottled or filtered jug water.
I just read it and I don't see where it says this. Only that the regulations regarding public drinking water are more rigorous. I actually saw nothing in the entirety of the article that contained any sort of actual conclusions on safety of bottled water. There were only conclusions regarding regulation and insinuations that lack of regulation may mean lack of safety.Gravenewworld said:GAO: tap water pretty much safer than bottled water
TheStatutoryApe said:I just read it and I don't see where it says this. Only that the regulations regarding public drinking water are more rigorous. I actually saw nothing in the entirety of the article that contained any sort of actual conclusions on safety of bottled water. There were only conclusions regarding regulation and insinuations that lack of regulation may mean lack of safety.
Among our other findings, the states’ requirements to safeguard bottled water often exceed those of FDA, but are still often less comprehensive than state requirements to safeguard tap water.
The product in question may contain a diluted form of a common food grade
cleaning compound that results in a bitter or sour taste. This could pose a
potential health concern if ingested in large quantities over an extended
period of time and should not be consumed or used in preparing infant formulas
or other foods or beverages. No illnesses have been reported.
cleaning compound...
gravenewworld said:There's also a link in the article to the full report. Does the GAO really need to explicitly state everything to get the point across? The GAO basically said tap water is safer because it has more stringent oversight to prevent things like this:
http://www.reuters.com/article/pressRelease/idUS160197+24-Jun-2008+PRN20080624
TheStatutoryApe said:That PDF isn't the report?
Mere lack of regulation does not make bottled water less safe than tap water. It makes it less regulated.
There are plenty of places out there where they have had scares about their tap water. Even just the plumbing in your home or apartment could be contaminating your tap water. I've drawn tap water in places where the water came out milky coloured and even brownish.
Public water systems must annually provide consumer confidence reports that summarize local drinking water quality information about the water’s sources, detected contaminants, and compliance with national primary drinking water regulations as well as information on the potential health effects of certain drinking water contaminants. FDA does not require bottled water companies to provide this information.
gravenewworld said:I fail to see how more information does not equate to more safety . Bottled water may be as safe as tap water, but who knows? The information out there to at least insulate this isn't out there because it isn't required!
On top of FDA regulation 80% of bottled water producers also belong to the International Bottled Water Association which has even more strict guidelines than the FDA and EPA. There are also other bottled water safety orgs besides the IBWA.We found that, for the most part, FDA’s bottled water standard of quality regulations are equivalent to EPA’s regulations for drinking water, but FDA has yet to set a standard for DEHP. Under the FFDCA, FDA is required to establish standard of quality regulations for bottled water that are no less stringent than the maximum contaminant levels established in EPA’s national primary drinking water regulations, and the agency has done so for most contaminants. In most cases where FDA has not adopted EPA’s national primary drinking water regulations, the agency has provided a rationale for not doing so. For example, FDA stated that it did not adopt EPA’s maximum contaminant level for asbestos or EPA’s treatment technique for the parasite Cryptosporidium because if municipal water is used as a source, it already has to meet EPA regulations, and it is unlikely that other sources of water, such as springs and aquifers, would contain these contaminants.
Cyrus said:Gravenewworld, I would like you to do the following:
(1) Not provide a link to a 50+ page pdf saying 'here read all this'. No one is going to do this. So if you have actually sat down and read this entire report, highlight the important pages you think are of particular interest to the rest of us.
(2) The quote you provided simply says that bottled water companies do not have to provide this information to the consumer, it did not say they don't have to pass the same standards (or even what those standards are) before it can hit the market. Therefore, what you said in bold above is a dishonest statement given the facts you have provided. It simply implies that bottled water is at *least* as good as tap water, but possibly better.
Of particular note, FDA does not have the specific statutory authority to require bottlers to use certified laboratories for water quality tests or to report test results, even if violations of the standards are found. Among our other findings, the states’ requirements to safeguard bottled water often exceed those of FDA, but are still often less comprehensive than state requirements to safeguard tap water
(3) This is nothing new. In fact, it's old news. So I'm puzzled as to why you are so surprised by this information.
TheStatutoryApe said:Here seems to be the primary issue that the report is concerned with...
Don't forget, states have their own guidelines for public tap water purity too. It sounds like CA state's regulations are even tighter than the IBWA's.n the Wal-Mart and Giant Food bottled water, the highest concentration of chlorine byproducts, known as trihalomethanes, was over 35 parts per billion. California requires 10 parts per billion or less, and the industry's International Bottled Water Association makes 10 its voluntary guideline. The federal limit is 80.
*snip*
The researchers also said the Wal-Mart brand exceeded California's limit by five times for a second chlorine byproduct, bromodichloromethane.
gravenewworld said:That's what the first link was for, it was a brief summary of the report that was pretty much only 3-4 pages. Why would I summarize a summary?
It is all in the first link.
It does not imply at all that bottled water is as good as tap. If the FDA is the only oversight watching bottled water manufacturers and they don't even have the power to obtain information about the quality of the water going into the bottles how does this imply that bottled water is as good as public tap water where much more comprehensive information on the quality of the water must be disclosed to an agency like the EPA?
Eh. You hear of stories like this, but this is the first time that I know of that something as big as the GAO has spoken about it.
Bottled water companies must submit to testing from government agencies as well as do their own testing. There is a whole section on all of the legally required testing in the report you cite.gravenewworld said:It is all in the first link. It does not imply at all that bottled water is as good as tap. If the FDA is the only oversight watching bottled water manufacturers and they don't even have the power to obtain information about the quality of the water going into the bottles how does this imply that bottled water is as good as public tap water where much more comprehensive information on the quality of the water must be disclosed to an agency like the EPA?
Unless you have some reason to disparage the IBWA, along with sources describing why, perhaps you should leave off the comments designed to discredit them?gravenewworld said:Sounds like another lobbyist group running Washington.
Regulations even tighter than the EPA's then? Did you not note that the FDA regs are very nearly the same as the EPA and IBWA's are tighter than the FDA's? So if California's are tighter than the IBWA's then they are probably even tighter than the supposed gold standard set by the EPA.Gravenewworld said:Don't forget, states have their own guidelines for public tap water purity too. It sounds like CA states regulations are even tighter than the IBWA's.
TheStatutoryApe said:Bottled water companies must submit to testing from government agencies as well as do their own testing. There is a whole section on all of the legally required testing in the report you cite.
Oh and perhaps you wouldn't mind finding out for us which lobbyists spurred the report you cite for your thread?
Did you not read the part where it said that state regulations on public water ways in many instances are even more strict than the FDA's? Like the MSN article said, for trihalomethanes the Federal limit (EPA) is 80 ppb while the state of CA requires it be under 10 ppb. The IBWA only makes it optional to be under 10 ppb. So yes, what you said in bold is true. Read Appendix II. It compares the standards of the FDA, EPA, and IBWA. In some cases the IBWA has higher standards than the EPA, while the EPA has higher standards than the IBWA in other cases. IBWA standards are a moot point in this issue for two reasons--one being the fact that bottlers aren't even required to submit to testing from certified labs and two the results of the tests don't even have to be disclosed to the FDA. What's the point of IBWA standards if the FDA can't even be sure it's being enforced?Regulations even tighter than the EPA's then? Did you not note that the FDA regs are very nearly the same as the EPA and IBWA's are tighter than the FDA's? So if California's are tighter than the IBWA's then they are probably even tighter than the supposed gold standard set by the EPA.
I wouldn't mind paying for bottled Yorkshire tap water here.cristo said:IIt seems like people over there don't mind paying a few dollars for a bottle of tap water!
cristo said:I remember that.. it lasted for a couple of weeks! I was amazed when I was offered a bottle of Dasani in the US when I asked for a bottle of water. It seems like people over there don't mind paying a few dollars for a bottle of tap water! Needless to say, I didn't!
Thats one of the concerns in the report - most bottled waters don't have added fluoride and (I really can't believe this) 9% of kids drink mostly or only bottled water.Moonbear said:Iso she gets some sort of bottled water that's fluoridated for the kid to promote healthy teeth.
Cyrus said:Could you at least summarize this 8 page pdf, rather than simply posting a one line question?
mgb_phys said:Thats one of the concerns in the report - most bottled waters don't have added fluoride and (I really can't believe this) 9% of kids drink mostly or only bottled water.
Australia town bans bottled water
A rural town in Australia has voted overwhelmingly to ban the sale of bottled water over concerns about its environmental impact.
JasonRox said:Please. It's more like 3 pages. You have a title page, a page that is blank, etc...
It's a 3-4 page summary to a 50 page report.
What do you want now? A summary to a summary?![]()
gravenewworld said:That's putting spin on it. The FDA devotes a laughable 2.6 FTE's for inspecting bottled water. The FDA almost never takes water samples. State inspectors are required to inspect the same way FDA inspectors do and they almost never take samples either. Bottlers are also not required to do their testing in certified labs like state water ways have to be tested against. Bottled water also isn't subject to the clean water act because it is treated like a food.
Read Appendix I. The GAO basically did a 3rd party investigation. It interviewed officials from both groups like EWG and IBWA as well as US government officials. So while the EWG probably did get the ball rolling on this issue, the GAO conducted its own investigation and came out with the report you read.
BTW the EPA standards listed in appendix II are only the EPA's maximum allowable levels. They say nothing about what the EPA really recommends.
mgb_phys said:Vancouver has banned bottled water on city council properties, they are trying to ban it in schools.
Cyrus said:Can you please provide a source for this statement, with a direct quote that supports what you have said?
Could you read Appendix I and properly quote the relevant portions. You can't post a 50 page .pdf and tell people "Go read (x,y,z)" and argue points in the meantime.
So now we must read two appendices?
Source, page number, paragraph?
Cyrus said:It's generally in poor taste to ask a question to something I already answered, Jason.
Office_Shredder said:Dude, did you even open the pdf? Go to appendix II. It's fricking obvious where the info you're asking for is in the appendix, since, y'know, the whole appendix is a table comparing those numbers. Do you really need him to cite "The top of the table I told you to open up and look at, but apparently you didn't?"
Cyrus said:I just opened the .pdf to Appendix (I & II). In Appendix I, I have multiple pages of text. In Appendix II, I see a list of contaminants on the rows and government agencies standards on the columns. In the OPs post he said:
No where do I see any context of what the numbers on this table shows. In addition, this is a multi-page table and I am not going to try and read or make heads or tails of every page of this appendix.
If I ever tried to present an argument like this to a professor I would promptly get my paper handed back with a rewrite.
JasonRox said:If you're not going to try and read anything, why are you even in this thread in the first place?
Cyrus said:I opened the thread with the hopes of having information being presented to me in the proper manner and context. I did not enter into this thread for a reading assignment; however, I will read portions highlighted by the OP *if* they are properly sourced and referenced. I hope I have finally explained this clearly enough for you to understand, Jason.
Bottled water has an excellent safety record in Canada. At the present time, no waterborne disease outbreaks have been associated with drinking bottled water in Canada.
Health Canada is currently reviewing the laws governing the production of bottled water, and said a proposal updating monitoring and testing guidelines will soon be made available.
JasonRox said:I hope you realize that PF is not a journal, Cyrus.
Cyrus said:Is that supposed to excuse anything? I fail to see why that means the quality of the thread/posts should be allowed to suffer because of it.
JasonRox said:You're right Cyrus. We should all walk around and talk as if it's going to be published in a journal.
That would be super.
I started reading more thuroughly and have found where it states that the FDA does not test every year but often contracts state agencies to do testing in its stead. Here it does not state whether this means that the state agencies do not test every year either. Besides this bottled water manufacturers are required to use only state approved sources of water. I'd imagine that these sources are approved by testing yes? And many of the manufacturers use the municipal water sources which are already tested by the EPA and contracted agencies yes? So further testing by the manufacturer and the FDA are just added protection in most instances.gravenewworld said:That's putting spin on it. The FDA devotes a laughable 2.6 FTE's for inspecting bottled water. The FDA almost never takes water samples. State inspectors are required to inspect the same way FDA inspectors do and they almost never take samples either. Bottlers are also not required to do their testing in certified labs like state water ways have to be tested against. Bottled water also isn't subject to the clean water act because it is treated like a food.
I didn't say they weren't lobbyists. I was referring to the manner in which you referred to them. Perhaps due to your choice in reading material and the sorts of documentaries you watch it does not register in your mind when you refer to agencies in a discrediting manner for no apparent reason?Grave said:Since when isn't the IBWA a lobbyist group? They tried filing lawsuits to block a tax on bottled water in NY and tried pressing the USDA to get water put into the food pyramid:
http://www.nytimes.com/2009/05/20/nyregion/20bottle.html
http://www.prweekus.com/pages/Login.aspx?retUrl=/Water-bottlers-lobby-to-get-onto-FDAs-food-pyramid/article/44087/&PageTypeId=28&ArticleId=44087&accessLevel=2 (not full article but remember reading about this in my college's newspaper back when I was an undergrad)
Grave said:Did you not read the part where it said that state regulations on public water ways in many instances are even more strict than the FDA's? Like the MSN article said, for trihalomethanes the Federal limit (EPA) is 80 ppb while the state of CA requires it be under 10 ppb. The IBWA only makes it optional to be under 10 ppb. So yes, what you said in bold is true. Read Appendix II. It compares the standards of the FDA, EPA, and IBWA. In some cases the IBWA has higher standards than the EPA, while the EPA has higher standards than the IBWA in other cases. IBWA standards are a moot point in this issue for two reasons--one being the fact that bottlers aren't even required to submit to testing from certified labs and two the results of the tests don't even have to be disclosed to the FDA. What's the point of IBWA standards if the FDA can't even be sure it's being enforced?
mgb_phys said:In Canada - Aquafina is just bottled Vancouver tap water.
The container itself may lead to such claims. My wife and I use Rubbermaid water bottles, not Nalgene or other hard plastics that can leach chemicals into the water. Since last year sometime, Nalgene phased out polycarbonates made with BPA, but there are many, many more producers still using it in other containers meant for food, water, and other liquids.Moonbear said:Yes, it seems the claim that tap water is safer than bottled water is a bit lacking in logic if so much bottled water IS tap water.
BPA is used in hundreds of everyday products. It is used to make reusable, hard plastic bottles more durable and to help prevent corrosion in canned goods such as soup and infant formula.
"If you heat those bottles, as is the case with baby bottles, we would expect the levels to be considerably higher," said Karin B. Michels, senior author of the report and associate professor at the School of Public Health and Harvard Medical School. "This would be of concern since infants may be particularly susceptible to BPA's endocrine-disrupting potential," she said.
http://www.cdc.gov/FLUORIDATION/fact_sheets/bottled_water.htmSome consumers use bottled water as a beverage for various reasons, including as a convenient means of hydration during their activities or as a taste preference. Besides having a cost that is between one-to-five thousand times more expensive than tap water, bottled water may not have a sufficient amount of fluoride, which is important for good oral health. Some bottled waters contain fluoride, and some do not. Fluoride can occur naturally in source waters used for bottling or be added. Most bottled waters contain fluoride at levels that are less than optimal for oral health. This fact sheet covers common questions about bottled water and fluoride.
