Gas density and mass (Attraction towards Earth)
Ozone, despite having a higher molecular mass than oxygen and CO2, is primarily found in the upper atmosphere due to its formation through photochemical reactions driven by strong solar radiation. Although denser gases typically gravitate towards the ground, the dynamic nature of the atmosphere, influenced by temperature variations and wind, allows for mixing that disrupts simple stratification by molecular weight. Ozone is unstable and continuously created and broken down in the upper atmosphere, where the conditions favor its formation. At ground level, ozone is less prevalent and considered a pollutant due to its oxidizing properties, as the intensity of solar radiation is reduced by the atmosphere. The discussion highlights the complex interplay between atmospheric chemistry and physical processes that determine gas distribution.
Raghav Gupta
How ozone having higher molecular mass then oxygen and CO2 is on a certain upper level of atmosphere?
Doesn't the more dense objects come closer to ground by gravitation?
DrClaude said:
Because that's where it is made
Okay but what about the high molecular mass?
Why above CO2?
Why above CO2?
Ozone is constantly being created by sunlight in the upper atmosphere, but it is also breaking down constantly as well, because ozone is unstable.
Also, gases stratify by molecular weight only in a situation where conditions permit. One of those conditions is that no mixing is occurring, due to temperature differences, for example. The atmosphere is a dynamic object, with the uneven temperature conditions created by having one portion heated by the sun causing winds to develop, which winds promote mixing of the atmosphere's constituent gasses.
There is a small amount of ozone present closer to the ground, but at these low altitudes, ozone is considered a pollutant, due in part to its oxidizing characteristics.
Likes Chestermiller
SteamKing said:
Ozone is constantly being created by sunlight in the upper atmosphere.
What is that particular condition that ozone is being created in upper atmosphere?
By distance above the ground what is happening?
Photochemical reactions.
Sorry, I am meaning that why can't photochemical reaction start at ground level?
Why only small amount of ozone at ground level?
To a certain extent, the reaction creating ozone does occur close to the surface of the earth, but at ground level, the intensity of the solar radiation reaching the ground is diminished by the blocking effect of the atmosphere itself. In the upper levels of the atmosphere where most of the ozone is created, the great majority of the atmospheric mass lies below, and the solar radiation responsible for creating ozone is much stronger.
Likes Raghav Gupta
Thanks to all of you.
See this link: http://acmg.seas.harvard.edu/people/faculty/djj/book/bookchap10.html
Chet
