Gas law problem (changing volume, temperature and pressure)
The discussion revolves around a gas law problem involving the volume, temperature, and pressure of a gas. The original poster seeks to determine the volume of a gas collected at 40°C and 75mmHg when it is adjusted to standard temperature and pressure (STP) conditions.
  • Participants discuss the initial and final conditions of the gas, with some questioning the clarity of the problem statement. There are attempts to clarify the definition of STP and its implications for the problem. Some participants express confusion regarding the pressure values associated with STP.
The discussion is ongoing, with participants exploring different interpretations of the problem and clarifying the conditions required for solving it. Some guidance has been offered regarding the use of the combined gas equation and the ideal gas law, but no consensus has been reached on the correct approach or values to use.
There is confusion regarding the pressure values for STP, with references to both 750mmHg and 760mmHg. Participants also note the importance of correctly identifying the initial and final conditions for the gas in question.
Tasha Clifford
What volume will 65cm3 of a gas occupy, if it is collected at 40°C and 75mmHg at STP?
None
I can’t quite work my head around this question, I am having a difficult time analyzing the question, I can’t seem to make out what the initial and final conditions are
would appreciate all the help I could get cheers
Edit: I mis-read the question. Please see post #4.
Either:
- it's a trick question and the answer is 65cm³ or
- there is missing information and the question is impossible to answer.
Tasha Clifford said:
Homework Statement:: What volume will 65cm3 of a gas occupy, if it is collected at 40°C and 75mmHg at stp?
Relevant Equations:: None
If the gas was collected at 40##^o## C and 75 mmHg then that is your initial condition. To find out what the volume is at any other condition you need to know what that condition is. You don't have enough information.
-Dan
On re-reading the question, I see it mentions 'stp' (which is normally written in capitals: STP).
I guess the question could be written as:
"A sample of (ideal) gas collected at 40°C and 75mmHg, occupies a volume of 65cm³.​
What volume will it occupy at STP?"​
What are your thoughts on this so far? How many moles of gas are collected?
-Dan
I just edited the question now, it end with “STP” which i didnt write in capitals, does this mean STP conditions are the final conditions
Brilliant, i think it makes much more sense now
And Does this mean STP conditions of 273K and 750atm are the final conditions?
75mmhg
750 atm! Ouch!
Before 1982 STP was defined as T = 273.15 K and P = 1 atm = 101.325 kPa.
After 1982 STP is defined as T = 273.15 K and P = 100 kPa.
You will need to check your source for the date. Either way, though, your calculations should be essentially the same.
-Dan
First tell us what you think!
And (as already noted by @topsquark ) you don't mean "750atm"!
the number of moles is the same at both states.
I meant 75mmhg and not 750atm sorry for the mixup😅
I do not quite understand what you mean here sir
Do i now proceed by substituting the said values in the combined gas equation
(P1V1 / T1 = P2V2 / T2 ) then find the final volume?
Maybe some confusion remains! Standard Temperature and Pressure (STP) corresponds to 0ºC and 750mmHg (but see note below).
Make sure you know the two different pressures in the question.
Note: In fact for STP, pressure = 750.06mmHg but 750 is often used as it is accurate enough for most purposes.
You're certain?
Yes. Post your working and answer and we'll check them.
As hinted at by @Chestermiller, you can also solve the problem using the ideal gas equation (PV=nRT) because the number of moles doesn't change. You might find it useful to try both methods to see that the two methods are really the same.
Bystander said:
You're certain?
Maybe you mean that there are various definitions of STP (some using 750.06mmHg and others using 760mmHg)?
I guess I should have pointed this out to the OP and suggested that they check which values (of both temperature and pressure) they are meant to use for STP. If @Tasha Clifford is reading this, please note!
However, the OP has used the figure '750' in the context of STP (rather than 760) suggesting 750mmHg is the appropriate value.
Note taken
I don't really understand how i can solve this question using the ideal gas eqaution, i just tried and it’s giving me an absurd value, would appreciate if you can do so , i want to see how you go about it
This is my working using the combined gas equation
You need to show your working and the value you got.
The rules here require you to show evidence of your own work before we can offer guidance. See https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
Did you manage to solve the problem using P₁V₁/T₁ = P₂V₂/T₂? Post your working - even if you got stuck at some point.
The original question says that the initial pressure, P₁ = 75mmHg, not 750mmHg.
The final conditions are SPT, so P₂ = 750mmHg. (That means pressure has increased by a factor of 10.)
Also, 1 atm is 760mmHg, not 750mmHg. It's wrong to say 750mmHg is 1 atm.
Try again!
Try again!
I am confused it’s actually an mcq qeustion, here is the question
Try again!
I just did the necessary corrections and solved it solved it again but my answer still doesn't fall among the provided answers
I just did the necessary corrections and solved it solved it again but my answer still doesn't fall among the provided answers View attachment 313765
I agree with your answer. Well done! It looks like the question and/or answer-list have one or more mistakes. It happens sometimes.
If we use the STP definition where pressure is 760mmHg and temperature is 0ºC, then I get the same answer as you.
(I would have rounded the answer to 2 or 3 significant figures, i.e. 5.6cm³ or 5.60cm³.)
If we use the STP definition where pressure is 750mmHg and temperature is 0ºC, then this changes the answer slightly, to 5.67cm³.
Make sure you know which definition of STP you are supposed to use. Using the incorrect definition will change the answer (slightly).
A very minor point: you correctly converted 0ºC to 273.15K. But the number you put into your equation was 273.
Yh i agree that there seems to be a problem with the qeustion because i realized that if you change the 75mmhg to 750mmhg then the answer becomes D) 55.9cm3
I still want to know how i could go about with the problem using the ideal gas equation as you said
Thanks anyway @Steve4Physics and @Chestermiller for all your contributions, I really do appreciate
Until next time
