Calculate Resulting Pressure of Mixed Gases in 12L Vessel
  • Thread starter Thread starter oceanflavored
    Gas Gas laws Laws
To calculate the resulting pressure of mixed gases in a 12L vessel at constant temperature, one can use the ideal gas law or convert the volumes to standard conditions. The initial volumes and pressures of neon, helium, and argon need to be considered to determine the total number of moles. Two methods are suggested: calculating moles directly or adjusting volumes to 1 atm before compressing to the desired volume. The final pressure is determined to be 2.0 atm, but the original poster is seeking clarification on the calculations. Understanding these methods is crucial for success in the upcoming AP Chemistry test.
oceanflavored
What is the resulting pressure when the quantities of gases listed below
are mixed and placed in a 12 L vessel at constant temperature?
4.0 L Ne measured @ 2.0 atm
2.0 L He measured @ 3.0 atm
2.0 L Ar measured @ 5.0 atm
P1V1=P2V2
the answer is 2.0 atm.and i have no clue how they figured that out.
because i tried to do it by the above equation. and that definitely did not work out.and then i tried adding up the initial volumes:8 L and the initial temperatures:10 atm.and that didn't work either.so basically;i need helpp.
and hopefully.before tuesday morning.because that's when my ap chem test is. which is why you see me here posting all these questions.
thanks a lot physicsforum people.you guys seriously save my life these days :redface:
One method: calculate the number of mole of each component, add up, use the perfect gas law for the desired volume.
Second method: convert all components as volumes for 1 atm, add up the volumes still at 1 atm, compress to the desired volume. (this method is the same as the previous one, but moles are replaced by "standard volume").
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
