Gas liquid contact in stripping column
The discussion focuses on the mathematical derivation of a formula related to gas-liquid contact in a stripping column. The initial equation (1) is presented, and the user seeks clarification on how to transition to the final result (2). Another participant suggests a correction to the formula, indicating that the denominator should be adjusted to reflect the correct summation. The conversation emphasizes the importance of proper notation in LaTeX for clarity. The thread highlights the collaborative effort to solve a technical problem in chemical engineering.
RAfAEL_SP
\frac{x[Ain]-x[Aout][/SUB][/SUB]}{x[Ain]-x[out][/SUB][/SUB]}=\frac{\sum s^{K}-1}{\sum s^K} (1)
for k = 0 to n
Final result:
\frac{x[Ain]-x[Aout][/SUB][/SUB]}{x[Ain]-x[/SUB][/SUB]} = \frac{{S-S^{n+1}}}{1-S^{n+1}}
(2)
Does anyone know how to get from (1) to (2).
Welcome to PF!
Hi RAfAEL_SP! Welcome to PF! :smile:
(use _ not SUB in latex, and use tex rather than itex for fractions that ou don;t want to be too tiny! :wink:)
for k = 0 to n
Final result:
(2)
I think you mean \frac{\sum s^{K-1}}{\sum s^K}
Then eg the denominator is (∑sK)/(1 - S) :wink:
The exponent is just k
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
