Gauss' Law and charges placed within a spherical conductor
A hollow spherical conducting shell with a total charge of -6 microCoulombs will induce a charge of -2 microCoulombs on its inside surface when a +2 microCoulombs point charge is placed inside. The charges on the outside of the shell do not influence the induced charge on the inside surface, as the conductor shields its interior from external fields. To find the electric field immediately outside the conductor, only the charges on the outer surface need to be considered, since the internal charge effects cancel out. The electric field outside is thus produced solely by the outer surface charges. Understanding these principles is crucial for applying Gauss' Law effectively in electrostatics.
accidentprone
A hollow sherical conducting shell is suspended in air by an insulated string. The total charge on the conductor is -6 microCoulombs. If an additional point charge of +2 microCoulombs is placed in the hollow region inside the shell what is the total charge induced on the inside surface of the shell.
I know already that a charge will be induce on the inside surface as a closed, hollow conductor shields its interior from fields due to charges outside, but does not shield
its exterior from fields due to charges placed inside it. However is the answetr simply that -2 microCoulombs will be induced on the inside of the sphere? Or will I have to account for the charge on the outside also interacting with the charge induced on the inside surface?
Many thanks in advance!
Yes, that's all there is to it.
No. They do not affect the inside surface charges.
Thank you!
One last question. I'm now asked to find the electric field immediately outside the conductor, given that the outside surface has a radius of 8 cm. Will The electric field outside be only produced by the charges on the outside surface as the inside and outside charges do not interact?
Effectively, yes. But electric field is always produced by all the charges--it's just that the effect of the charges inside the outer surface is zero: They cancel out.
Thank you again, especially for the speedy replies - much appreciated!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
