Calculating Gravitational Potential Using Gauss's Law for a Thin Rod
tatiana_eggs
Calculate the gravitational potential due to a thin rod of length l and mass M at a distance R from the center of the rod and in a direction perp. to the rod.
integral form of Gauss's law wrt gravitation
Can I use Gauss's law here i.e. solve for the gravitational field vector and integrate it to get gravitational potential? If not, why?
I tried but I don't get the same answer as with direct integration.
Yes, it should be possible to solve that way. You might want to try to show your work in case someone here can spot a mistake.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
