Solving Gauss's Law Problem: Excess Electrons in Plastic Sphere
  • Thread starter Thread starter A.J.710
    Gauss's law Law
To determine the number of excess electrons needed to create an electric field of 1250 N/C outside a plastic sphere with a diameter of 23.0 cm, the equation E=Q/4*pi*ε*r^2 was used. The calculated charge was found to be 7.353*10^-9 C. Dividing this charge by the elementary charge (1.602*10^-19 C) resulted in approximately 45.9 billion electrons. The initial confusion arose from using the diameter instead of the radius in calculations. Correcting this error clarified the solution process.
A.J.710
How many excess electrons must be distributed uniformly within the volume of an isolated plastic sphere 23.0cm in diameter to produce an electric field of 1250N/C just outside the surface of the sphere?
E=Q/4*pi*ε*r^2
I've attempted to find the charge using that equation and got 7.353*10^-9. Then to find the number of electrons I did 7.353*10^-9/1.602*10^-19 and I get 45904610632 electrons. It keeps saying I am wrong and I can't figure out why. Can anyone please tell me if I am doing something wrong.
Thanks
NEVERMIND. They threw in 23cm as the diameter and not the radius...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
