Did I make a mistake in finding the third generalized eigenvector for A?
The discussion centers on finding the third generalized eigenvector for the matrix A = [1 1 1; 0 1 0; 0 0 1], which has an eigenvalue of 1 with algebraic multiplicity 3 and geometric multiplicity 2. It is noted that two true eigenvectors can be identified, but the third generalized eigenvector should satisfy the equation (A - I)v2 = v1, where v1 is a true eigenvector. The confusion arises from the expectation that the third generalized eigenvector should be found in Ker((A - I)³), but it is clarified that it should actually be in Ker((A - I)²). The conversation emphasizes the importance of understanding Jordan bases and the correct application of the theorem regarding generalized eigenvectors. Overall, the participants agree that reviewing the relevant mathematical notes would be beneficial for clarity.
Gear300
I remember reading a theorem that said that for an n x n matrix A, there exists a basis of Cn consisting of generalized eigenvectors of A.
For A = [1 1 1; 0 1 0; 0 0 1] (the semicolons indicate a new row so that A should be 3 x 3 with a first row consisting of all 1's and a diagonal of 1's). The eigenvalue of A is 1 with an algebraic multiplicity of 3 and geometric multiplicity of 2. So I can pull out a basis of 2 vectors from Ker(A-uI). For the third generalized eigenvector, it should be in Ker((A-uI)3), but that produces 0v = 0, in which v could be any vector in Cn...did I do something wrong here?
Mathematics news on Phys.org
It's been really long since I did linear algebra, so forgive me if I say anything stupid.
You get two "true" eigenvectors (1, 0, 0) and (0, 1, -1) (or scalar multiples thereof).
Then shouldn't the third generalised eigenvector satisfy
\left. (A - \lambda I) \right|_{\lambda = 1} \vec v = (1, 0, 0)^\mathrm{T},
with the first eigenvector on the right hand side rather than 0?
this is explained in great detail in the notes for math 4050 in my webpage.
briefly, you factor the characteristic polynomial, find the bases of the kernels of the corresponding powers (T-c)^r.
this is called a jordan basis. it is tedious to do in practice.
You're right, though I haven't fully read how so yet.
I was just thinking that this actually makes sense. The whole point that you need generalised eigenvectors here, is that the algebraic multiplicity of the eigenvalue is larger, so if you calculate them in the normal way, you will get a null eigenvector somewhere, which is not allowed.
And if you solve the equation (A - I) v2 = v1, where v1 satisfies (A - I)v1 = 0, then you will indeed get an eigenvector in ker((A - I)²) (which in this case is equal to the whole space since (A - I)² is the zero matrix). So you are right that the generalised eigenvector you are looking for is inside ker((A - I)²), it is just not any vector in it.
But as I said, it's been a long time, so we're both better of reading mathwonk's notes, I think :-)
in reference to post #1, you want an exponent of 2 instead of 3, on (A-uI).
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
