Generating a pulse of high frequency and very small duty cycle
The discussion revolves around generating a pulse with an ON time of 10-50 ns and a time period of approximately 1 µs. Participants explore methods to achieve this precision using basic components, suitable for a second-year project.
  • Exploratory, Technical explanation, Homework-related
  • One participant expresses a need for generating a precise pulse with specific timing parameters.
  • Another participant suggests that commercial frequency generators can achieve the desired output but questions the feasibility of using them due to potential cost or size issues.
  • A participant requests suggestions for methods to generate the pulse using basic and inexpensive components available in a lab setting.
  • It is mentioned that various circuits can produce pulses of variable lengths, and resources like textbooks and online searches may provide additional information.
  • One participant seeks clarification on whether the desired ON time needs to be variable or if a steady pulse within the specified range is acceptable, proposing the use of a crystal oscillator and divider circuit as a potential solution.
Participants have not reached a consensus on the best method to generate the pulse, and multiple approaches and considerations are presented without resolution.
The discussion includes assumptions about the availability of components and the potential variability of the pulse width, which remain unresolved.
akipro
Hey,
I wanted to generate a pulse of ON time of about 10-50 ns and time period of around 1us. Don't know how to get such precision ?
Thanks
Commercial frequency generators can do this. If that is too expensive (or too large, or whatever): Where is the problem with the short duty cycle?
@mfb
I wanted to make it for one of my second year project with basic( generally also cheap) components available in lab.
It could be heplful if you could suggest any method of achieving it.
There are many circuits which can give pulses of variable length. I am sure textbooks, google and other methods to search for them will give results.
akipro said:
Hey,
Thanks
akipro said:
@mfb
Welcome to the PF.
When you say ON time of 10-50ns, does that mean it has to be variable, or you just want a steady pulse with a value somewhere in that range?
If a steady pulse width in that range works, you can just use a simple crystal oscillator and divider circuit plus a little glue logic. Since this is your school project, can you take those hints and describe how it can be done?
