Generating Circular Polarization II
Two dipole antennas oriented 90 degrees apart can generate circular polarization when one radiates a cosine function and the other a sine function. The electric field produced by these antennas can be expressed as a combination of their respective components in the x and y directions. To analyze the electric field at a specific location in the z direction, the relationship between time and distance is established using the wave number, which relates to the wavelength of the wave. The equation ωt - βz = constant describes points moving in the z direction at a constant velocity, illustrating the nature of traveling waves. Understanding these concepts is crucial for grasping the dynamics of circular polarization and wave propagation.
jeff1evesque
Statement:
Consider two dipole antennas, oriented 90degrees apart [imagine the x-y plane, let "a" be the dipole oriented along the x-axis, and the "b" be the dipole oriented along the y-axis]. If "a" dipole radiates cos(\omega t) and "b" dipole radiates sin(\omega t), the field radiated by the two antennas will be circularly polarized:
\vec{E}(z, t) = E_{0}[cos(\omega t - \beta z)\hat{x} + sin(\omega t - \beta z)\hat{y}] (#1)
Relevant Question:
Ok I almost get it now. Now in terms of a specific distance, say in the \hat{x} direction, the cosine function has traveled a distance \omega t (as did the sine function in it's respective axis). But I don't understand why To find electric field at a given location in the \hat{z} direction, we subtract the distance traveled \omega t by the wave number times distance in z, or \beta z - for each component \hat{x}, \hat{y}. The wave number is the wavelength of the sinusoid per unit distance. What happens when we take this wave number \beta and multiply it by z? What does that represent, I cannot see the relation between the two (\omega t and \beta z)?
Does one unit length of z = 1 for \beta z \hat{x} and \beta z \hat{y} correspond to a length of \frac{2\pi}{\lambda} in the \hat{z} direction?
I think we should talk about the simpler case of linear polarization, since your question is with the concept of traveling waves rather than about circular polarization.
So ... let's represent an electromagnetic wave by
Ex(z,t) = E0 cos(ωt - βz)
and the electric field happens to be polarized in the x-direction.
Now consider points in space such that
ωt - βz = constant ≡ φ​
where we are calling this constant "φ".
We can say 2 things about what this represents:
  • it represents points moving along the z-direction at constant velocity, which we can see by solving the above equation for z:
    z = (ω/β)t - (φ/β)​
  • it represents a fixed electric field strength of E0 cosφ
Combining those two facts, it means that the entire electric field pattern moves along the z-direction at a speed (ω/β). And that's just what a traveling wave is.
