Generator Power Output: 17.038 KW/60 RPM - Is it 61336.8 KWH?
  • Thread starter Thread starter ENRG
    Output
The discussion centers on the power output of a generator producing 17.038 kW at 60 RPM from a 2000 ft lb per second source. There is confusion regarding whether this output translates to 61336.8 kWh when calculated over an hour, with some participants asserting it should be 17.038 kWh for that duration. Clarification is provided that kW represents kilojoules per second, and to convert to kWh, one must multiply the kW by the number of hours. The importance of understanding the difference between kW and kWh is emphasized. Ultimately, the thread highlights the need for precise unit comprehension in power calculations.
ENRG
Hi everybody:
Help me out with this if you don't mind.
A 2000 ft lb per second source rotates a generator shaft at 60 RPM; It is generally agreed (not by everyone) that this produces 17.038 KW of power.
What is not clear is if this is 17.038 KW per SECOND then the total HOURLY power would be calculated : 17.038KW *60* 60= 61336.8 KWH.
Some say that the total production of this generator is 17.038 KWH (IN ONE HOUR)
What say you?
kWH = kW * H
EDIT -- removed the confusion which then followed...
What say you?
Yikes - you have to know what a kW and a kWh are. Check the units: Since the "h" is hours, kW * h = kWh
kW is kilojoules per second, but don't let that confuse you - if you want kWh, you just need the kW and the number of hours.
Yikes is right. :-p Thanks for catching my error Russ. I'll edit my post to remove the confusion.
Shoot. To late to see the confusing goodies.
:rolleyes: Riiiiight...your error... um, I guess I should have read your post...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
