cyt91
- 53
Given a convex lens of focal length of (x+5) cm and a concave lens of focal length x cm.
The 2 lenses are placed 30 cm apart coaxially i.e along the same axis with the convex lens on the left while the concave lens is on the right. A light bulb is placed to the left of the convex lens at a distance of 10 cm. It is observed that light rays that emerges from the concave lens are parallel to each other. Find the value of x.
[tex]\frac{1}{f}[/tex]=[tex]\frac{1}{u}[/tex]+[tex]\frac{1}{v}[/tex]
Since the light rays that emerges from the concave lens are parallel,the light rays that emerges from the convex lens converges at the focal point of the concave lens.
Therefore,
[tex]\frac{1}{x+5}[/tex]=[tex]\frac{1}{10}[/tex]+[tex]\frac{1}{30-x}[/tex]
[tex]x^{2}[/tex]-45x+100=0
Solving for x, x=2.344 or 4.266
The answer given is x=2.655.
Part of the solution given involves the equation
[tex]\frac{1}{x+5}[/tex]=[tex]\frac{1}{10}[/tex]+[tex]\frac{1}{30+x}[/tex]
instead of [tex]\frac{1}{x+5}[/tex]=[tex]\frac{1}{10}[/tex]+[tex]\frac{1}{30-x}[/tex]
They've added a negative sign to the focal length of the concave lens i.e. -x instead of x.
Is the solution correct?
I feel the solution is wrong because we shouldn't add a negative sign to x (the focal length of the concave lens) since x is a variable.
