Geometry: What Theorem Is This?
  • Thread starter Thread starter wubie
    Geometry Theorem
The discussion centers on identifying a theorem related to the angles formed when two intersecting lines create collinear points. The angles AHC and BHD, as well as AHD and BHC, are identified as vertical angles, which are equal according to the vertical angles theorem. Participants clarify the notation used to describe the points and their relationships, debating the necessity of specifying collinearity. The conversation emphasizes the importance of clear definitions in mathematical proofs. The vertical angles theorem is confirmed as the relevant theorem for the proof in question.
wubie
Hello,
I cannot remember what the theorem is in which the following happens:
Given two lines l and m which intersect each other, let H be the point of intersection.
Let A and B be points on the line l such that AHB are colinear. And let C and D be points on the line m such that CHD are colinear.
Now what is the theorem/lemma/corollary which states that when two such lines intersect in such a way that
angle AHC = angle BHD
and
angle AHD = angle BHC ?
I need to quote it for a proof that I am doing. I can't remember for my life. And I can't seem to find it in my notes/text. It's not a big problem, I would just like to quote it properly.
Any help is appreciated. Thankyou.
You also need A*H*B and C*H*D (H is between A and B, and H is between C and D). The theorem is called the vertical angles theorem.
vertical angles
Don't know if it has a catchy name. How about the "vertical angles are equal" theorem? (The angles you mentioned are called vertical angles.)
edit: beaten again!
Thanks Hurkyl and Doc Al. By the way,
Isn't that implied with the notation AHB and CHD and stating that they are colinear on their respective lines l and m?
Cheers.
I haven't seen such notation used before, but it certainly wouldn't surprise me that some would use it. As long as your teacher knows what it means. :smile:
Actually, once you have said "Let A and B be points on the line l" and said that H is the point where the two lines intersect, it is not necessary to say (again) that they are "collinear". I don't believe that just saying "AHB are collinear" is a standard way of saying that H is between A and B.
I think I see what you mean.
Would simply stating
Let AHB be points on the line l and let CHD be points on the line m.
have been adequate then?
