Calculating Altitude of a Geosynchronous Satellite Orbiting Jupiter
  • Thread starter Thread starter Bashyboy
    Satellite
To calculate the altitude of a geosynchronous satellite orbiting Jupiter, the satellite must maintain the same rotational period as the planet, which is 9.84 hours. The relevant equations involve gravitational force and angular velocity, leading to the calculation of the orbital radius. An initial attempt yielded an incorrect radius of 1.59 x 10^8 m, prompting a re-evaluation of the calculations. The altitude above Jupiter's surface is found by subtracting the planet's average radius from the calculated orbital radius. Ultimately, the correct altitude can be determined by ensuring proper unit usage and calculations.
Bashyboy
A synchronous satellite, which always remains above the same point on a planet's equator, is put in orbit around Jupiter to study that planet's famous red spot. Jupiter rotates once every 9.84 h. Use the following data to find the altitude of the satellite above the surface of the planet. Jupiter has a mass of 1.90 \cdot 10^{27}~kg, and a mean radius of 6.99 \cdot 10^{7}~m.
v= \large \sqrt{ \frac{GM_j}{R_j + h}} M_j mass of Jupiter; R_j average radius of Jupiter.
v= \large \sqrt{ \frac{GM_j}{r}}
v_{tan}=r\omega
I know that in order for the satellite to continually be suspended above the same spot on Jupiter, they have to be rotating through the same angles and take the amount of time to rotate through those angles. Hence, \omega_j=\omega_s= \frac{2\pi}{35424~s} (I converted the hours to seconds).
I thought of using the first forumula; but when I substituted
v_{tan}=r\omega and tried to solve for r, it became rather difficult. And so, I opted to use the second equation and perform the same steps. I solved for r, r= (\large \frac{GM_j}{\omega^2})^{1/3}
After the final substitution, r= 1.59 \cdot 10^8 m. This, however, isn't the correct answer. What did I do wrong?
You solved for r. What altitude does that correspond to?
Oh, I need to subtract the average radius from the value of r I found. Also, I just noticed that the mass of Jupiter was given in kg, should I have converted it into grams?
Right.
No. Kg is the standard unit for mass.
You are asked about the altitude above the surface of Jupiter.
I got the proper answer. Thanks be to you both.
