Get the area between two curvess
  • Thread starter Thread starter madinsane
    Area
madinsane
Okay, so here are the two functions, f(x)= sqrt(x+3) and g(x) = (x+3)/2
my first step was to get the intersection points and it came out to be x=1 or -3
Then I drew a graph and that told me that the function sqrt(x+3) is always above the other function on the entire interval. So then I did integral f(x)-g(x) dx with upper and lower limits 1 and -3 and the integral gave me (using u substitution as well) 2/3(x+3)^3/2 - 1/4 x^2 +3/2x and then I put in the x values and got 13.3.
Okay so the problem is that the answer in the book is 4/3 and I have no idea where I have gone wrong. Can anyone put me on the right track and tell me where I went wrong
I believe the problem is in the integral. That x term looks wrong, I suggest you integrate again and see where you went wrong, because yours is different than my solution and my solution gets the right answer.
Just to be a bit more clear, your actual integral is correct, but you made an error integrating.
edit:
Misread something, but yeah what arildno says works :).
Your flaw lies in your lack of parentheses in your integrated -g, you should have -(1/4x^2+3/2x) as your choice of anti-derivative, rather than what you wrote.
Thank you. I realize my error now :)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
