Getting geodesic from variational principle
LCSphysicist
The metric is $$ds^2 = \frac{dr^2 + r^2 d\theta ^2}{r^2-a^2} - \frac{r^2 dr^2}{(r^2-a^2)^2}$$
I need to prove the geodesic is: $$a^2 (\frac{dr}{d \theta})^2 + a^2 r^2 = K r^4$$
My method was to variate the action ##\int\frac{(\frac{dr}{d\theta})^2 + r^2 }{r^2-a^2} - \frac{r^2 (\frac{dr}{d\theta})^2}{(r^2-a^2)^2} d \theta##
But the equation i am getting is $$a^2 (\frac{dr}{d \theta})^2 + r^2 = K (r^2-a^2)^2$$
Which can not be reduced to the answer.
I am a little confused, i could simpy calculate the Christoffel symbol, but i think this variation method easier, yet i am not sure how to use it.
So basically, my guess on why i have got the wrong answer is that the "lagrangean" i am variating is wrong. So what lagrangean indeed give us the right answer? Only ##g_{ab} \frac{dx^a}{ds} \frac{dx^b}{ds}= 1 ## and ##\sqrt{g_{ab} \frac{dx^a}{d\lambda} \frac{dx^b}{d\lambda}}##? Or the lagrangean i used above is right, and i have done some algebric error?
Your approach failed because in general the Euler-Lagrange equations produced from L_1(r, dr/d\theta) are not the same as those obtained from L_2(r, dr/d\theta) = \sqrt{L_1}: <br /> \begin{split}<br /> \frac{d}{d\theta} \left( \frac{\partial L_2}{\partial r&#039;}\right) - \frac{\partial L_2}{\partial r}<br /> &amp;= \frac{d}{d\theta} \left( \frac{1}{2L_2} \frac{\partial L_1}{\partial r&#039;} \right) - \frac{1}{2L_2}\frac{\partial L_1}{\partial r} \\<br /> &amp;= \frac{1}{2L_2} \left[\frac{d}{d\theta} \left( \frac{\partial L_1}{\partial r&#039;}\right) - \frac{\partial L_1}{\partial r}\right] + \frac{\partial L_1}{\partial r&#039;} \frac{d}{d\theta}\left( \frac{1}{2L_2} \right) \\<br /> &amp;\neq \frac{1}{2L_2} \left[\frac{d}{d\theta} \left( \frac{\partial L_1}{\partial r&#039;}\right) - \frac{\partial L_1}{\partial r}\right]<br /> \end{split}<br /> If you take s as the independent variable then you can work with f(r) r&#039;^2 + g(r) \theta&#039;^2 directly because by definition its total derivative with respect to s is zero and you end up with the same Euler-Lagrange equation as you obtain from \sqrt{f(r) r&#039;^2 + g(r) \theta&#039;^2}.
You have a Lagrangian system
$$L=\dot r^2\Big(\frac{1}{r^2-a^2}-\frac{r^2}{(r^2-a^2)^2}\Big)+\frac{r^2}{r^2-a^2}\dot\theta^2.$$
You must consider this system at the energy level ##L=1##
perhaps the following cyclic integral will be of use
$$\frac{\partial L}{\partial \dot \theta}=const$$
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
