Gibbs Free Energy of Formation: 1°C or 25°C? (And other exciting questions.)
Using the equation ΔG=ΔG°+RT ln Q to calculate the energy yield of a reaction requires careful consideration of the temperature at which ΔG° is determined. It is crucial to use ΔG° calculated at the same temperature as the reaction, as different temperatures yield different equilibrium constants (Q). For example, if the reaction occurs at 50°C, the corresponding ΔG° should also be derived for that temperature, rather than using values from 1°C or 25°C. If ΔG° values at the desired temperature are unavailable, linear interpolation between known values can be a rough approximation, but more accurate results can be obtained using the van't Hoff or Gibbs-Helmholtz equations. Additionally, ΔG°' (with a prime) typically refers to standard conditions for biochemical reactions, which may differ from standard thermodynamic conditions. Understanding these distinctions is essential for accurate thermodynamic calculations.
Danny.Boy
Hi there:
When using ΔG=ΔG°+RT ln Q to calculate the energy yield of a reaction, does it matter if I use ΔG° calculated at 1°C or 25°C? Also, why are there two choices and when are they each applicable? Finally, I have also seen ΔG°' written (note the prime). What does this mean and how does it differ from ΔG° conceptually and numerically?
I realize that these are very basic questions, so if you want to point me towards some elementary reading material I understand.
Thanks in advance,
Danny.Boy
Chemistry news on Phys.org
Yes, it matters. If you use Delta G at 1 deg C, then you will also have to use a corresponding T and then equilibrium constant will be that for this temperature. The same way using Delta G at 25 deg Celsius yields Q for this very temperature.
The change of Q with temperature can be calculated with the van't Hoff equation:
http://en.wikipedia.org/wiki/Van_'t_Hoff_equation
Thanks for your reply DrDru, but I'm afraid I don't really follow. Perhaps a concrete example would help me understand. For example, consider this reaction at 50ºC (i.e., 323.15K):
[A]+→[C]+[D]
Using ΔG=ΔG°+RT ln Q, I get something like this:
ΔG=ΔG°+R×323.15×ln (([C][D])/([A]))
but what is the value of ΔG° that I should use? The value at 1ºC or 25ºC?
Neither of the two but the value at 50 deg. Celsius.
If you have both the values at 1 and at 50 degrees, you could linearly interpolate as a first approximation.
But, as I said, it would be more exact to calculate the value of Delta G0 at 50 degs from the van't Hoff or Gibbs-Helmholtz equation, see:
http://en.wikipedia.org/wiki/Gibbs-Helmholtz_equation
E.g. ##T_1=1^\circ##C, ##T_2=25^\circ##C and ##T_3=50^\circ##C,
then
##\Delta G^0(T_1)/T_1-\Delta G^0(T_2)/T_2=\Delta H ^0(1/T_1-1/T_2)##.
Solve this for ##\Delta H^0## and then solve
##\Delta G^0(T_1)/T_1-\Delta G^0(T_3)/T_3=\Delta H ^0(1/T_1-1/T_3)##
for ##\Delta G^0(T_3)##.
Aha! Makes sense. Thanks for explaining that.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
