Girl Climbing Rope: Avg Speed & Work Calculated
  • Thread starter Thread starter Grey_117
    Girl Rope
To match the power output of a 200-W lightbulb, the average speed of a 55.0 kg student climbing a 4.00 m rope can be calculated using the power formula P = W/time. The work done by the student can be determined using the gravitational potential energy equation, which is W = mgh, where m is mass, g is acceleration due to gravity, and h is height. The discussion emphasizes the importance of identifying relevant equations for solving the problem. Participants encourage sharing thoughts on applicable equations rather than just presenting the question. Engaging with the forum can lead to a better understanding of the concepts involved.
Grey_117
A 55.0 kg student climbs a 4.00 m long rope and stops at the top.
(a) What must her average speed be in order to match the power output of a 200-W lightbulb?
(M/S)
(b) How much work does she do?
(J)
Well if i had to guess...they might be
P=W/time total
1/2Mvf^2-1/2mvi^2
It's OK to be unsure of the relevant equations but not OK when you only give the question. The forum is here to help you, not to do your homework for you.
So don't be shy; which equations do you even half-suspect may be relevant?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
