Given mass, distance, and time, calculate power
  • Thread starter Thread starter MathMajor
    Mass Power Time
The discussion revolves around calculating the power exerted by a weightlifter lifting a 50kg barbell over a distance of 1.2m in 1.5 seconds. One participant calculated the power as 392 Watts by incorporating gravitational acceleration, while their professor claimed the answer is 40 Watts based on a simplified work calculation. The correct approach requires converting mass to force using gravity, confirming that 392 Watts is indeed the accurate power output. Participants emphasize the importance of using proper units and calculations in physics problems. The consensus supports the calculation of 392 Watts as the correct answer.
MathMajor
How much power does a weightlifter expend when lifting a 50kg barbell a distance of 1.2m in a time interval of 1.5s?
Power=work done/time interval (in Newton meters per second or Watts)
Work=Fd (in Newton meters or Joules)
Power = Fd/t = (m)(a)(d)/t = 50kg(9.8 m/s2)(1.2m)/1.5s = 392 Nm/s = 392 W
This is how I solved the problem, but my professor said the correct answer is 40 Watts!
Work = force x distance; work = 50 kg x 1.2 m, work = 60
Power = work /time; 60/1.5 = 40 Watt
Can someone please verify which way is correct? I am sticking by my answer of 392 Watts
'50kg' is a mass and not a force, it must be correctly multiplied by acceleration (gravity in this case) to convert it to a force. You are correct.
Ok, so you are sure the correct answer is 392 Watts? I feel like I will be shunned for going against the professor, but I have to go with my gut on this one.
Thanks!
Thanks!
I didn't check over your answer, but I am quite sure that 'kg' is a unit of mass and not force.
I agree. Thanks!
