Given value of a line integral, find line integral along different curves
SithsNGiggles
Given value of a line integral, find line integral along "different" curves
I think I've got this figured out, so I'm just checking my answers:
Suppose that
\int_\gamma \vec{F}(\vec{r}) \cdot d\vec{r} = 17,
where \gamma is the oriented curve \vec{r}(t) = \cos{t} \vec{i} + \sin{t} \vec{j},
0 \leq t \leq \pi/2.
Use this to evaluate the line integrals in 1-3.
1. \int_{C_1} \vec{F}(\vec{r}) \cdot d\vec{r}, where C_1 is the curve
\vec{r}(t) = \sin{t} \vec{i} + \cos{t} \vec{j},
2. \int_{C_2} \vec{F}(\vec{r}) \cdot d\vec{r}, where C_2 is the curve
\vec{r}(t) = t \vec{i} + \sqrt{1-t^2} \vec{j},
0 \leq t \leq 1.
3. \int_{C_3} \vec{F}(\vec{r}) \cdot d\vec{r}, where C_3 is the curve
\vec{r}(t) = \sqrt{1-t^2} \vec{i} + t \vec{j},
0 \leq t \leq 1.
I realize that each curve \vec{r} represents a quarter-circle in the first quadrant, and \gamma and C_3 have a counter-clockwise direction starting at (1, 0), whereas C_1 and C_2 have a clockwise direction starting at (0, 1).
\vec{F} is the same in each case, right? And if so, are the answers simply
1. -17
2. -17
3. 17?
Thanks!
Sure. What could be wrong with that?
:rolleyes: I'm not sure how to interpret that... It can easily be mistaken for sarcasm.
It's not. I just meant that your understanding is clear enough I can't think what to add. Suppose I should have said that.
Ok. Thank you!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
