Good design for a PWM that has a adjustable start current and. .
In summary, the conversation involves a request for a good design for a pulse-width modulation (PWM) circuit with adjustable start current and ramp up time. The design requirements include the application, voltages, and current levels, as well as the option for using a simple analog circuit or a more sophisticated microcontroller-based circuit. There is no standard circuit to start from, but a 555 IC and H-bridge are mentioned as possible components. The PWM and radio controls will be separate chips for prototyping. The conversation also mentions a Wikipedia page with information and examples of PWM circuits.
rockstar
any body have a good design for a p.w.m that has a adjustable start current and ramp up time
That's too general a question, rockstar. You need to say more about the application, voltages, current levels, etc. And whether you want to use a simple analog circuit, or a more sophisticated microcontroller (uC) based circuit to do the PWM. Is this for the RC vehicle application that you mentioned in another post? If so, what does the controller look like in the standard circuit before you started modifying it?
there is no standard circuit to start from. i was hoping something as simple as a 555 ic and it'll be controlling the H bridge mentioned in the other post. for simplicity i just built a standard h bridge for now out of uprated parts, the H-bridge and the P.w.m. will be a separate chip from the radio controls, for the sake of prototyping (sorry about the vague question)
FAQ: Good design for a PWM that has a adjustable start current and. .
What is a PWM and what does it do?
A PWM (Pulse Width Modulation) is a technique used to control the amount of power being delivered to a load by varying the duty cycle of a square wave signal. It can be used in various applications such as motor speed control, power supplies, and LED dimming.
Why is it important to have an adjustable start current in a PWM?
An adjustable start current allows for a gradual increase in power to the load, reducing the risk of sudden spikes in current that can damage the load. It also allows for more precise control over the start-up process, especially in sensitive systems.
How can a PWM with adjustable start current benefit a system?
A PWM with adjustable start current can help increase the efficiency of a system by reducing power wastage during start-up. It can also protect the load from potential damage and allow for smoother operation of the system.
What factors should be considered when designing a PWM with adjustable start current?
Some important factors to consider include the maximum and minimum start current required for the load, the desired ramp-up time, and the type of load being controlled. It is also important to consider the power supply and circuit components needed for the PWM to function properly.
Are there any limitations to using a PWM with adjustable start current?
One limitation is that it may require more complex circuitry and components, which can increase the cost of the system. Additionally, the start current may need to be adjusted manually or through a control signal, which may not be feasible in some applications. It is important to carefully consider the specific needs of the system before implementing a PWM with adjustable start current.
