How Fast Does a Stone Shoot from a Rubber-Band Slingshot?
A rubber-band slingshot launches a 25g stone, with a force of 27 N applied over a distance of 0.15 m, resulting in an energy of 4.05 J. The user attempts to calculate the initial speed of the stone using the kinetic energy formula but initially arrives at an incorrect speed of 5.69 m/s. The confusion arises from the conversion of mass from grams to kilograms and the application of energy formulas. After double-checking the mass conversion, the user realizes the mistake and acknowledges the need for correction. Accurate calculations are essential for determining the correct initial speed of the stone.
XxphysicsxX
the problem is:
A rubber-band slingshot shoots a 25-gstone. What is the initial speed of the stone if the rubberband is drawnback 0.15m with aforce of 27 N?
m= 25g
d=0.15 m
f= 27 N
v(initial) = ?
Ep = (1/2)Fx
Ek=(1/2) mv^2
so far, I turned the forceto energy: (27N)(0.15m)= 4.05J
and then solved for v, using Ek= (1/2)mv^2
and I get v=5.69
Im so confused, this answer deffinetly does not seem right..
Im just not sure what to do with the given force here!, do I turn it into work ? (w=fd)
I've been stuck on this question for two days now,i just don't understand how any of the givens can tie in with the energy formulas..?
Your method was correct, however your calculation for the value of v is incorrect, as it is too low. You should get a larger answer.
Well, I am using the exact numbers given ,just converting grams to kg, ...
Ek= (1/2)mv^2
4.05J= (1/2)(0.25)V^2
4.05J/0.125 =V^2
V=5.69
Where am I making a mistake?? :s
Ek= (1/2)mv^2
4.05J/0.125 =V^2
V=5.69
Double check the mass.
Woww, I feel stupid now, haha,
Thankyou!:biggrin:!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
