Grade 11 Chemistry Problem about a Nonreaction
  • Thread starter Thread starter student34
    Chemistry Grade 11
The discussion centers on the reaction between Hg(NO3)2(aq) and CH3COONa(aq), concluding that no reaction occurs. Participants emphasize the importance of identifying the ions present in solution and understanding their nature, such as whether they are salts, acids, or bases. The lack of a reaction is attributed to the absence of any insoluble products or acid-base interactions. The conversation encourages critical thinking about the chemical species involved and their potential interactions. Ultimately, the conclusion is that no reaction takes place in this scenario.
student34
If there is a reaction, write out the chemical equation for
Hg(NO3)2(aq) + CH3COONa(aq)
N/A
The answer says that there is no reaction. I have absolutely no idea why not.
N/A
In all of these reactions. Think about what is in solution. In this case, what ions are in solution.
When you know what kinds of ions are in solution, think a bit about what kind of species they are (salts, acids, bases)
If you have an acid and a base, you might expect an acid-base reaction. If you just have salts, think about whether any of the new pairings would result in an insoluble salt.
Basically: What do you have in the beaker. What kinds of reactions do the species undergo?
Likes student34
If you have no idea why not, than perhaps you have an idea about why yes? Do you see anything that can react here? Can you predict any products?
Likes student34
Oh I see, thank-you so much! :)
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
