Grade 12 Physics-Finding the Spring Constant
In summary, the conversation discusses a mini-lab where a rubber band was stretched and fired horizontally to determine its elastic coefficient. After obtaining known data from the experiment, such as mass, height, distance flung, and stretched length, the attempt at a solution involved finding the time and velocity components. However, there was confusion regarding the relevance of gravity and the initial kinetic energy. After correcting a mistake in mass conversion, it was determined that the rubber band used may not have been accurately weighed, as it was described as being much larger than the reported mass of 0.3g. This may have affected the calculated elastic coefficient.
physicsjunkie1
This was a mini-lab and the task was to fire a rubber band by stretching it a known distance, shooting it straight horizontally from a known height. Based on where the rubber band lands determine the elastic coefficient. Known data from experiment: mass=0.30g, height=0.412m, distance flung=1.362m, stretched length (Δx)=0.047m.
d=vt
Ee=1/2k(Δx)^2
Eg=mgh
Ek=1/2m(v)^2
We tried to find the time with the vertical component
d=Vit+1/2at^2, acceleration is 9.8m/s^2
we got t=0.28997s
Then we used the horizontal component to get the velocity
d=vt
v=4.697m/s (initial velocity)
then we found the final velocity using a=(Vf-Vi)/(t)
we got Vf=7.53m/s (right before the rubber band hits the ground)
Then we thought that Eg+Ee (lost)=Ek (gained)
We solved for k, but got 6.62, which is not the right value because it is too small. There must be a problem with our method. We think maybe it has something to do with the acceleration formula used to find the final velocity. We aren't sure what we did wrong but let us know if you have any corrections or any other methods to approach this question with.
d=vt
Ee=1/2k(Δx)^2
Eg=mgh
Ek=1/2m(v)^2
we got t=0.28997s
d=vt
Good so far.
Why would you need the final velocity? The contribution of the rubber band ends when the initial velocity is obtained.
We thought we needed a final velocity to put into the Ek formula. Do we just use Vi for the v variable in Ek=1/2m(v)^2.
That formula is generally correct. For the initial velocity, it gives you the initial kinetic energy.
So what would you do after finding the initial velocity in the d=vt formula?
Where does the initial kinetic energy come from?
The elastic potential plus the gravitational potential energy is converted into kinetic energy.
Gravitational potential energy is converted into the initial kinetic energy? How?
We flung the rubber band from a height of 0.412m, so it initially had Eg.
So at the beginning it had Eg and Ee and then when the rubber band landed 1.3m away, it had all converted to Ek, we thought.
I thought we sorted out the (ir)relevance of "landing" in posts #1 - #3.
So is it Ee=Ek then ?
I am not sure what those symbols mean. Is Ee the elastic potential energy? Then it is correct.
yes Ee is elastic potential
Why don't you consider the fact that there is gravitational potential and that the elastic travels a certain disance?
Again: what relevance does the gravity have on the work of the rubber band?
Okay, I see what you're saying now but when I use Ee=Ek and sove for the spring constant, I only get 1.9.
I get about 30 N/m from your data. Show your working in details.
are you converting the mass correctly? I am still getting a different answer
I can offer no further help unless I see exactly what you do.
Ee=Ek
(1/2)kx^2= (1/2)mv^2
(1/2)k(0.047)^2=(1/2)(3.0 x 10^-4)(4.967)^2
0.0011045k= 0.00309271
k= 0.00309271/0.0011045
k= 2.8
(1/2)(3.0 x 10^-4)(4.967)^2 is not 0.00309271 but a little more.
Anyway, the result is close to 3 N/m which I am getting now. I think I did make a mistake in mass conversion.
Which brings me to this: are you sure it really was 0.3 g? That is very tiny. The rubber density is about 1000 kg per cubic meter, which makes that volume 0.0000003 cubic meter, or about a cube with 7 mm side; your reported extension is about 7 times that size.
Im almost positive that is the correct mass and I googled masses of other rubber bands and they're all less than a gram. If the mass is larger it would make sense and that's the only place I can see that is the problem.
The only realistic shape I can think that would have this mass is a thin and long strip of rubber; that should indeed have low stiffness. Can you describe the shape and its dimensions, even if approximate?
It is just a few centimetres in diameter. Its a circular rubber band, kind of thick and pretty stiff.
4.7cm in diameter to be specific.
a 1 gram rubber-band is 6mm wide, almost 1mm thick, and 180mm circumference.
hmm. that 47mm diameter is not accidently the same as the stretch?
that is, Ee = ½ k s^2 , where s is the distance the rubber has been stretched.
The elastic was originally 4.6cm long and was stretched to 9.3cm long, for a difference of 4.7cm.
No way that cylinder of rubber can be just 0.3 g. It is far too large for that. Either the dimension or the mass is way off.
FAQ: Grade 12 Physics-Finding the Spring Constant
1. What is the spring constant?
The spring constant, also known as the force constant, is a measure of the stiffness of a spring. It represents the amount of force required to stretch or compress a spring by a certain distance.
2. How is the spring constant calculated?
The spring constant can be calculated by dividing the applied force by the displacement of the spring. This can be represented by the equation F = kx, where F is the applied force, k is the spring constant, and x is the displacement.
3. What units are used to measure the spring constant?
The spring constant is measured in units of newtons per meter (N/m) in the SI system, or pounds per inch (lb/in) in the imperial system.
4. How does the spring constant affect the behavior of a spring?
A higher spring constant indicates a stiffer spring, meaning it will require more force to stretch or compress the spring. Similarly, a lower spring constant indicates a less stiff spring, requiring less force for the same amount of displacement.
5. What factors can affect the value of the spring constant?
The spring constant can be affected by factors such as the material and shape of the spring, the temperature, and any external forces acting on the spring. It is important to keep these factors constant when conducting experiments to accurately determine the spring constant.
