(GRADE 9 SCIENCE) Equilibrium Tension Force Help Me PLease
In the discussion, a freshman seeks help with a Physical Science problem involving equilibrium and tension forces. Participants emphasize that in a state of equilibrium, the sum of forces in both horizontal and vertical directions must equal zero. The user identifies initial forces as 350, 250, and 250 for three questions but struggles with understanding tension forces related to a pulley system. Guidance is provided that tension remains constant as it passes over a pulley, leading to further analysis of the forces acting on the blocks involved. The conversation focuses on clarifying concepts of equilibrium and tension in physics.
RunningBack
Hey Guys,
Well I am a freshman taking Physical Science and my teacher didn't do a good job explaining this question.
http://prntscr.com/uf6tv <-- that's the problem and i numbered the 6 questions
If you could answer those questions and explain how you got that it would be awesome!
thanks
Well for starters, if the system is in equilibrium, what can you say about the sum of the forces in the both horizontal and vertical directions?
You will need to show an attempt or at least some thoughts about how you would start the question. My hint above gives you the starting point.
ok the sum needs to add up to zero..
so that means
#1 is 350
#2 is 250
#3 is 250
i don't understand the tension force part now #4 #5 #6?
you've done good so far. Now #5 is just due to the definition of a pulley. It is fairly intuitive. Would we expect the tension in the rope to change as it goes over the pulley, or just stay the same? Then after that, you can consider the other forces on the block m3
