Graduate School for Engineering
The discussion centers on the decision to attend graduate school for engineering immediately after undergraduate studies or after gaining work experience. Key points include the advantages of pursuing graduate studies right away, such as full funding opportunities and the ability to engage in research, which may be more challenging to do later while working. Conversely, entering the workforce first offers a break from academia, higher initial salaries, and the chance to explore different fields. Participants emphasize the importance of personal passion for research when considering a PhD, noting that while both a Master's and a PhD can lead to better career prospects, a PhD is often necessary for advanced research positions. Ultimately, the consensus leans towards pursuing a Master's degree immediately to capitalize on academic momentum and research opportunities.
tyro1
I really have no doubt that I will attend graduate school some time or another in my life. My question is about the choice of attending it straight out of undergrad, or after having worked for a few years.
I am on a co-op term, and I will return to my 4th year at a Canadian university this september. I will be faced with the decision soon enough.
Things going on in my head
Grad School pro:
1.More school! Yay!
2.prospects of ending up with a better career!
3.full funding, only condition being acceptance, and possible scholarship if my grades are high enough
4. Finish my Graduate degree earlier
Straight to Workforce pro:
1. Break from School!
2. Chance to explore fields of interest
3. Salary will be significantly higher than graduate school funding
4. boring job (most likely)
What other pros to each side should I consider?
Care to provide any life examples?
Thanks.
One thing that pushed me was the research. When many people get their masters later in life, they do it while working a job. So, they end up doing the class-only option which excludes (for the most part) any type of research.
The research was what I really wanted to do, so that's why I went straight in after undergrad.
It is best to do it straight out of school at least for a Masters.
You have to realize this when you get a Masters you will most likely get a better salary earlier on in your career. If you calculate how much this ends up at accumulatively at the end of your career then it could be in the 100,000's.
Plus ones you have a job you will adapt a lifestyle conform to your salary. It will be very hard to go back and give that up for school again.
Is there a general expectation from the university for Research Masters student to go into PhD when they finish their masters? At any rate I guess they can't force me to stay.
Thanks for your tips, It does seem like the general consensus is to go straight into grad school. Especially when it comes to getting reference letters.
I thought of a new question to ask. Is there a significant difference in perceived value between a Masters and a PhD when employers are looking at new hires?
Reason why I as is that I've seen research positions that ask "Masters OR PhD" as if they don't see much difference between the two.
There IS a huge difference do. Although not all jobs require a PhD, for some either or will do. A PhD will allow you to do more R&D type work either at a big business (GE, Rolls Royce, GM etc) or at any of our national labs (Lawrence Livermore, Argonne, GPL ..etc). Now a Masters will not be sufficient for these jobs (typically).
Now, in my personal opinion, a PhD should not purely be done as a career move but also should be coming from a passion for the topic.
yea, you are right, That is one of the things I am worried about when choosing area of research in grad school. I may like the sound of a research area, but once I get into it, I may not like it.
I think I will go for a masters first, and go out into the work place, try to find out about hot and interesting research fields, and If I decide I want to dedicate my life to a certain field, then I will go to grad school
thanks again for your advice.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
