Predict Grain Diameter at 650°C After 199 min
  • Thread starter Sniperfx20
  • Tags
    Diameter
In summary, the average grain diameter for a metal alloy was measured as a function of time at 650°C, with results tabulated for two different times. With the given information, one can predict the grain diameter after 199 minutes at the same temperature if n=2, assuming a quadratic function in a grain growth or diffusion equation.
Sniperfx20
The average grain diameter for a metal alloy was measured as a function of time at 650°C. The results are tabulated below:
Time Grain diameter
(min) (mm)
30 3.9 x 10-2
90 6.6 x 10-2
Predict what the grain diameter would be (in mm) after 199 min at the same temperature if n=2.
any ideA?
Hi Sniperfx20, welcome to PF. Can you tell us what n is? It would also be helpful if you told us any equations that you've been given along with showing your attempt at the problem.
Time Grain diameter
(min) (mm)
30 3.9 x 10-2
90 6.6 x 10-2
any ideA?
Looks like a grain growth problem. One has two sizes and two times, and one is trying to use a function. Is 'n' an exponent to a growth or diffusion equation? If so, then n=2 is a quadratic function.
1. What is the purpose of predicting grain diameter at 650°C after 199 minutes?
The purpose of predicting grain diameter at 650°C after 199 minutes is to understand how grain size changes over time and at different temperatures. This information can be used to improve industrial processes, such as metal casting, by controlling grain size for desired properties.
2. How is grain diameter at 650°C after 199 minutes predicted?
Grain diameter at 650°C after 199 minutes can be predicted using mathematical models and experimental data. These models take into account factors such as temperature, time, and material composition to estimate the change in grain size over time.
3. What factors can affect the accuracy of the prediction?
The accuracy of the prediction can be affected by various factors, such as the quality and availability of data, the complexity of the material system, and the assumptions made in the mathematical models. Other factors, such as experimental conditions and sample preparation techniques, can also influence the accuracy of the prediction.
4. How can the predicted grain diameter at 650°C after 199 minutes be validated?
The predicted grain diameter can be validated by comparing it to experimental results. This involves conducting experiments at the predicted conditions and measuring the actual grain diameter. If the predicted and experimental results are in close agreement, it can be considered a validation of the prediction.
5. Can predicting grain diameter at 650°C after 199 minutes be used for other materials?
Yes, the prediction of grain diameter at 650°C after 199 minutes can be used for other materials as long as the relevant data and parameters are available and applicable to the material system. However, it is important to note that the accuracy of the prediction may vary for different materials and may require further validation.
