Graphing Terminal Velocity using Euler's Method
3 replies · 6K views
jinksys
Suppose an object of 20kg is shot upward with an initial velocity of 20m/s. The drag coefficient I've chosen is 0.25, and gravity is 9.8m/s. I'm trying to calculate the terminal velocity using Euler's Method (using a C prog), and then graph the data using openoffice. I know I am converging to the correct terminal velocity, however I'm not confident in my graph of acceleration vs time.
Does this look right?
http://i36.tinypic.com/10p4jmh.png"
Here is my code:
PHP:
#include <stdio.h>
#include <unistd.h>
#include <math.h>
#include <stdlib.h>
double accel(double v);
double velocity(double v, double a, double t);
int main()
double a,v,t,time;
v=0.0;
t=0.01;
a=1.0;
time=0.0;
printf("Velocity, Acceleration, Time,\n");
while(fabs(a)>0.00001)
	a=accel(v);
	printf("%f, %f, %f,\n",v,a,time);
	v=velocity(v,a,t);
	time+=0.01;
double a,k,g,m;
k=0.25;
g=9.8;
m=20.0;
if(v!=0.0){
	a=(-k*v*v*fabs(v));
	a/=m*v;
	a-=g;
	return a;
	return -9.8;
v = v + (a * t);
return v;
Hi jinksys,
The shape of the curve looks fine to me; was there something in particular that bothered you about it?
alphysicist said:
Hi jinksys,
Well, my professor said that my graph of velocity vs time http://i38.tinypic.com/51368i.png" is correct. However, since my acceleration is essentially a graph of the velocity's slope, the "wiggle" around -9.8 should represent something on my velocity graph around 0m/s. He's not seeing where I get the wiggle.
So you're saying the graph looks correct? What is causing the wiggle?
The wiggle on the a vs. t graph occurs at arount t=2, and that corresponds to what is happening at t=2 on the v vs. t graph.
If you look at the acceleration curve, it starts out at about -14.8 or so, and then the wiggle is at -9.8m/s, and then it rapidly goes to zero.
This corresponds to the velocity curve: initially it has a slope of about -14.8; the slope changes to -9.8 around t=2 seconds and the wiggle is showing that that slope stays approximately constant arount t=2 seconds.
I think if you change your drag coefficient to about 2.5, and look at the a and v curve at around t=1 second, it is easier to see what is going on. (Notice that around t=0 the v curve is sloped, around t=1 is approximately straight, and past t=1 it curves again.)
The thing to remember is that the acceleration curve gives the slope of the velocity curve: so these wiggles (which are where the acceleration curves are not changing very much) indicates that the velocity slope is roughly a straight line at that time.
