Gravatational Potential Energy Question
To calculate the energy required to move a satellite from an altitude of 1RE to 3RE, one must determine the gravitational potential energy (GPE) at both altitudes. The total energy for a satellite in orbit includes both kinetic and potential energy, and the energy difference between the two orbits will provide the required energy for the move. The user is struggling with the calculations and seeks clarification on the correct approach to find the GPE values. Understanding the relationship between altitude and gravitational potential energy is crucial for solving the problem. Accurate calculations will yield the necessary energy for the satellite's transition between orbits.
SherazSiddiqu
How much energy is required to move a satellite from an altitude of 1RE to 3RE?
1RE= 1 x Radius of the Earth
I tried to find the the GPE of the oject but its not working.
What's the total energy for a satellite in orbit? Then simply find the energy difference between the two orbits.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
